Old 09-06-2011, 09:19 AM
gil2602 is on a distinguished road
Bridgeport XR-1000 Alarm
I have a 609:x and y inverter radiator fan failure. However, both fans are running. This alarm appears as soon as the machine is started.
Any ideas as to what might be causing this?
Old 09-06-2011, 05:04 PM
*Registered*
Bpt Service is on a distinguished road
These are small fans that are part of the heatsink unit on the back of the drive. The heat sink fins are subjected to the coolant mist fro the machine and they get all gummed up. to get to them pull the drive unit out, remove the fan and clean with solvent until you can spin it by hand than re-install
Bridgeport VMC 1000 XP3 cncdon CNC Machining Centers 6 01-28-2011 11:47 AM
Bridgeport VMC 1000 417m Open Source CNC Machine Designs 1 01-07-2011 12:12 PM
bridgeport VMC 1000/20 spddsgn Bridgeport and Hardinge Mills 2 10-10-2010 08:52 PM
Bridgeport VMC 1000 kayleesdad Bridgeport and Hardinge Mills 10 01-09-2006 10:56 AM
Bridgeport VMC 1000 kayleesdad General Metal Working Machines 2 07-18-2005 10:20 AM
