Old 09-02-2011, 01:55 AM
Jori_N is on a distinguished road
Bridgeport Serie 2 Interact 4
Hi!
I bought old bridgeport milling machine with TNC 150 control. We use it with seller and everything work properly.
Firstly it gives "POWER interupted" i reset it with CE-button. Then i press "power enable" on. This far everything works properly. Then I press "feed" on to start servos, but nothing happens. In this position there appears wierd sign like X in monitor. If I but "STOP" button sign disappears same happens if i press some limit switch. Theres allso text KEY NON-Functional.
When I was moving machine x+ limit switch frame went broke and I get it out and fix it. Can this cause some error?
Hopefully some one can help me with this problem.
-JN-
Old 09-02-2011, 07:31 AM
christinandavid's Avatar
christinandavid is on a distinguished road
* will appear when machine tries to reference axes at start-up. In manual (hand) mode, you press cycle start for each axis in turn, with potentiometer (feed override) at 100%
DP
Old 09-02-2011, 10:18 AM
DP
Thank`s for your answer, but it not working. I allso change Z axis belt and now Z axis is about halfway down. Theres some inductive sensor top of machine and when i touch it with some metal I can active cycle start. When i pres Z- putton, it asks DATUM SET, what value should I give. I have trying different values, but nothing happens.
-JN-
Old 09-02-2011, 05:49 PM
Can't understand why things are breaking or needing replacing if all worked properly with seller...maybe some photos showing the position and state of the machine would help.
As I recall, the only reason for a properly working machine not to move is low lubrication oil. Fill it up and give it a few pumps. Is the seller still available to help you out?
DP
Old 09-04-2011, 11:59 PM
DP
Thanks, some times you have to replece old parts, like belts in this situation. Now I get Z-axis belt away and move Z- axsis in upper position. Now mahcine is moving, if I firslty push little micro switch next to that inductive sensor. It`s possible that micro shiwth is moving little, when we were moving that machine. under that switch, is some kind of lock or brake what stops Z-axis, it`s effecting pulley wheel.
Anyway, now when the machine is moving it gives position error. Y-axis drives in limit switch, I think mahcine don`t know home position.
-Jori-
Old 05-22-2012, 11:08 AM
heliosaucedo87 is on a distinguished road
bridgeport textron serie II
i have the same machine and i have the same problem,
i buy 2 weeks ago and yesterday i try to use and when i turn on the power the monitor says "power interrupted" are not what happened ? help?
Old 05-23-2012, 06:15 AM
Moderator
machintek is on a distinguished road
That switch shuts off the Z axis during a tool change. The paw holds the Z axis from moving down during a tool change.
George
Need Help!- bridgeport interact 720 foseguera Post Processors for MC 5 01-17-2010 10:04 PM
Actualizacion cnc bridgeport serie 1 R2E3 puerto paralelo kalito Spanish CNCzone 2 11-01-2009 04:39 PM
Bridgeport serie 2 interact2 tnc 145 proplem.Please help! stenly Bridgeport and Hardinge Mills 6 02-23-2009 12:09 PM
Bridgeport Interact 412 Gncc50 Bridgeport and Hardinge Mills 2 02-02-2009 07:09 PM
Z-axis Problem Bridgeport CNC serie 1 Rufan Bridgeport and Hardinge Mills 5 08-09-2005 08:31 PM
