Old 09-01-2011, 06:23 PM
R6YNO9 is on a distinguished road
series 1 r2c3 tnc 145 ref pass over not workig
machine was dead too long and had to hand load parameters from someone her and it worked for everything except when a parameter needed to say NO all i could get input was YES no matter what number or minus or plus sign Z axis is moving up until it hits the first micro then it speeds up and hits the over travel limit and gross error thing comes up this is a 1982 machine any ideas would be helpful r6yno9@yahoo.com
Old 09-02-2011, 07:44 AM
gus gus is offline
gus is on a distinguished road
the correct parameters for this machine are posted on this forum
to toggle yes/ no it is ent /noent
get a manual
Old 09-03-2011, 09:17 AM
thanks i will try ent or noent
i did get the parameters from here and it only lets me load about 50 or so then the screen reads cross over the ref points will try reloading with yes and no correctly thanks
Old 09-03-2011, 10:19 AM
would like to get a manual got the numbers here and will try and find one
got Z to ref thanks GUS but cant get X or Y to move yet
cnc machines at work sure are work savers (im a toolmaker)
Old 09-04-2011, 09:42 AM
gus gus is offline
Sooooooooooooooooo.....
what happens when you try to home x and y?
the r2c3 is very similar to the interact virtually the same wiring diagram
i believe I posted a bad copy of a wiring diagram at some point
Old 09-08-2011, 09:20 AM
bp series 1 r2c3
im watching the boards as i try and home and can see led lite up for Z(4 of them) and a only 2 lite up while Y is trying ---got some loose wires from traveling 1,000 miles i guess ---- X dont lite any up at all just hear the switches clicking as i move joy stick each direction
need a good wiring diagram got all operation manuals and set ups from Heidenhain site
Need Help!- BP Series I R2C3 w/ 151b controler Sroe1 Bridgeport and Hardinge Mills 8 02-15-2011 03:44 PM
Bridgeport Series 1 R2C3 Problems Vigilance Bridgeport and Hardinge Mills 3 12-28-2010 05:21 PM
Bridgeport R2C3 manual ps2727 Bridgeport and Hardinge Mills 9 10-09-2010 08:08 PM
Need Help!- Way cover for R2C3 BP cnc mill Trump Bridgeport and Hardinge Mills 0 12-13-2009 08:26 PM
r2c3 troublewith switch Dar Bridgeport and Hardinge Mills 2 08-24-2007 04:09 PM
