Old 08-23-2011, 11:27 AM
secretdirty is on a distinguished road
Bridegport 2HP Head
Hey
I noticed a strange sound on my Bridgeport milling machine so i was wondering if anybody knows where this noise comes from?!?
It seems to be in the upper area of the milling Head!
Old 08-23-2011, 04:14 PM
*Registered*
Bpt Service is on a distinguished road
The shift handle on the RH side needs adjusting...Do this while running the head and making the noise...While pressing the slit shift handle assy inward towards the head with your left hand loosen the two screws that tighten it around the shaft once both screws are loose the clutches will adjustment location and the noise will go away...do not let go off the handle assy until you re-tighten the screws
Old 08-23-2011, 04:48 PM
re
Is there any drawing ? my english is not that good :-)
Shift handle on the RH side? RH?? And what's the slit shift handle assy?
Sorry lot of stupid questions i guess!!
Old 08-23-2011, 07:44 PM
*Registered*
File attached. Place shift handle in Hi range, then so procedure.
Old 08-23-2011, 07:58 PM
re
Thanks a lot !!I'll try it tomorrow and give you feedback if it works!!
Need Help!- vac head??? Lucid DIY-CNC Router Table Machines 10 07-08-2011 08:51 AM
IH Head ways head lose issue Rich05 Industrial Hobbies (Support forum) 4 03-15-2011 12:06 PM
Reversing Tapping head vs Tension/Compression tapping Head apeman88 Tormach PCNC 4 01-25-2011 08:39 AM
Need Help!- W head brockadeau BobCad-Cam 0 09-28-2008 06:33 AM
Problem- bridegport R2E4 needs to re-home theguild Bridgeport and Hardinge Mills 6 09-20-2008 05:10 AM
