Old 08-20-2011, 11:05 AM
Andy_mr2sc is on a distinguished road
Bridgeport 720x with TNC2500 Control Look Ahead
Hi all,
I have recently purchased a Bridgeport 720x mill with a Heidenhain TNC2500 control. I have connected a pc link to download programs from my pc but am having a few issues.
I don't seem to be able to drip feed a program so the size of program I can send is limited. Is this usual for this control or do I need to change the parameter settings?
I am getting a lot of stop/starting on corners with lots of lines in. I use arcs where I can but sometimes my software generates lines instead. I don't think the control is looking at the next lines until it has finished one. Is there a way of altering this or is there a 'smoothing' parameter that can be used to get round this?
Regards,
Andy.
Old 08-21-2011, 09:16 AM
mod-mec is on a distinguished road
Originally Posted by Andy_mr2sc View Post
Hi all,
Regards,
Andy.
Hi Andy, for starters you should be using the TNCremo to transmit, you can download the page Heidenhain. As for the braking of the corners is fixed in each block adding M90 G01 have to make this work you must have a machine parameter enabled can not remember which is for your, but I'm going to find out. The program line should read something like:
N10 G01 X0. Y0. M90 *
I hope this information serve you.
Old 08-21-2011, 04:51 PM
Hi
I am using TNC Remo to send programs to my mill. I am using Heidenhain language though not G code. The M90 still works the same way with it and I use it on my programs but I am not sure it is working. As you say there may well be a parameter to change to fix this. If you can find this it would be appreciated.
Regards,
Andy.
Old 08-22-2011, 09:04 AM
Try parameter 1390.0 from a 0 to 1 that should work.
Old 08-28-2011, 01:03 PM
I've changed Parameter 1390 but I'm still getting the same symptoms. Does M90 need to be on every move line? My post puts it only on the first one.
Old 08-28-2011, 08:47 PM
I had the same problem and solve it by changing that parameter and placing M90 in each block to move in G01. The m90 is not modal, when executed automatically disables the block.
Need Help!- Bridgeport Interact 2 Series 2 TNC2500 theo1 Bridgeport and Hardinge Mills 4 01-19-2012 05:14 AM
Bridgeport VMC1000/20 Vertical Machining Centre with Heidenhain TNC2500 Control bptnc2500 Bridgeport and Hardinge Mills 7 12-09-2010 12:36 AM
Need Help!- Look Ahead Control Disabled laser jim G-Code Programing 4 06-12-2009 12:35 PM
Problem- Bridgeport Interact 308 w/TNC2500 GarageShop Bridgeport and Hardinge Mills 4 03-24-2008 05:43 AM
TNC2500-Bridgeport 412 Parameters paulmenday Bridgeport and Hardinge Mills 4 02-01-2008 02:22 AM
