Old 08-11-2011, 08:35 AM
Tailgunner is on a distinguished road
Problem Bridgeport series 1 CNC?
I' m just about to buy a Bridgeport series I CNC with Boss 5 control.
I went to the owner today. The machine looks in pretty good shape.
He bought the machine to do a retrofit but he hasn't got the time anymore and needs the space it takes up. So the machine is in its original state.
There is one problem though:
The spindle (z) moves up and down when using the controls. However if you want to move the x- and y-axis, nothing seems to happen. It seems to me that the motors are turning (the motors make a soft noise) but no movement. He tells me that it has moved in the past and thinks he has done something to the settings causing this problem.
Does anyone know what the problem could be?
Old 08-12-2011, 07:24 AM
Moderator
machintek is on a distinguished road
Probably a shorted transistor on those axis. 2N6547 Motorolla. This is the most common issue with these machines but with the proper input voltage and the current set correctly I have seen them run for years without blowing one. Search the posts for this.
George
Old 08-12-2011, 10:48 AM
George
I know the owner has switched the input voltage from 3x220 V to 380 V.
Maybe something went wrong there.
When I get my hands on the machine, it will be the first thing I look into.
Old 08-16-2011, 01:52 AM
TarHeelTom is on a distinguished road
I disagree.
Remove the computer cabinet and sell it for scrap. Actually, there's a bunch of stuff inside you might want to save, like the heat sinks.
Install a PC, a bob, and Gecko 203V or 213V drives, and EMC2. You'll have a much more capable machine, and you're going to only spend a bit over $1000 to do it.
http:///tomwade.me/tw/machinist/nm/
Tom
Old 08-17-2011, 11:03 AM
Thumbs up
Originally Posted by TarHeelTom View Post
I disagree.
Tom
I just want to have it up and running. If I can do that by replacing a few transistors that won't be a big deal. Maybe I'll start with the hillbilly bob and keep the original drivers, just for starters.
I know that modern electronics are a better choice, but I'm just getting started in this machining world and don't want to make expensive mistakes.
Thanx for the advice and I love your website
Old 08-28-2011, 06:27 PM
amishmafia00 is on a distinguished road
I would highly recomend the hillbilly board, I have been very happy with mine. for the price it's hard to beat. I would recomend getting all axes working before you start the bob install.
Problem- Bridgeport Interact 2 Series 2 Problem theo1 Bridgeport and Hardinge Mills 4 06-05-2011 06:53 AM
bridgeport series 1 cnc (boss 6) problem Klunk CNCzone Club House 0 04-02-2009 04:28 AM
Need Help!- Bridgeport Series 1 CNC - 56 VDC problem? John Maher Bridgeport and Hardinge Mills 2 12-01-2008 04:11 PM
Series 2 cnc 2 hp motor on a series 1 bridgeport? CATCH22 Bridgeport and Hardinge Mills 1 11-08-2008 08:18 AM
Bridgeport Series 2 Interact 2 Power hook up problem! Help! Huntersyv Bridgeport and Hardinge Mills 7 01-09-2006 01:57 AM
