Results 1 to 2 of 2
Thread: Bridgeport Interact 1 MkII "Gross Positioning Error D"
    Oct 2010
    England
    Hi all, first day with my mill, it is going fine but I was manually transversing along the X axis when it must have gone just over the limit and now displays the error message.
    It is at the position where it stops when you fire the machine up and travels to the extents of X and Y, so to me it seems like it has hit a switch or something, I'm extrememly new to this so would appreciate any help ASAP!!!
    Thanks,
    TC
    p.s. It is using a T151 control.
    Oct 2010
    England
    Is ok figured it out!
    I am getting a random Z axis fault now though which says limit reached occasionally but if I cancel and run the program again it is fine, and fine manually etc...
  1. Need Help!- Bridgeport Gross positioning error
    By Ogre4x4 in forum Bridgeport and Hardinge Mills
    Last Post: 02-26-2011, 05:45 PM
  2. "Gross Postioning Error A" Doing M03 on Bridgeport Interact Series 1 Mk2
    By MeTri in forum Bridgeport and Hardinge Mills
    Last Post: 12-28-2009, 12:37 AM
  3. Bridgeport Interact 4-Gross Positioning Error
    By foolmaker in forum Bridgeport and Hardinge Mills
    Last Post: 01-15-2009, 04:13 PM
  4. Need Help!- Interesting "Gross Position ERROR A" with no limit detection
    By A.A in forum Bridgeport and Hardinge Mills
    Last Post: 01-14-2009, 03:45 PM
  5. HELP! Gross positioning error
    By crazeekev in forum Bridgeport and Hardinge Mills
    Last Post: 09-09-2008, 11:11 AM
