Old 08-04-2011, 12:40 PM
jthornton is on a distinguished road
DX32 Work Offset
I have a BP Discovery 308 with DX32 control.
Is there some way to have a work offset on this control? I use EMC2 for some of my machines and you just switch to one of the coordinate systems and set the offset. Is there something like this in the DX32?
John
Old 08-04-2011, 01:10 PM
ss_again is on a distinguished road
I believe you are talking about G97. You can offset your work coordinate system by G97X_Y_Z_ where X_Y_Z_ is the distance from the base coordinate system to the new one. Use G96 to cancel. G97 can be used over many times in a program.
Old 08-04-2011, 01:29 PM
Thanks, that will work fine for me. I completely missed that paragraph in the manual.
John
Need Help!- No Work offset Jelle_b_k G-Code Programing 1 06-16-2011 01:22 PM
Work offset question Barefootboy4 Mach Software (ArtSoft software) 2 01-25-2011 11:07 AM
Need Help!- work offset Claude Boudreau BobCad-Cam 3 11-22-2009 05:41 PM
Problem- 6M-B 4th & 5th axis work offset changes R-Bob Fanuc 0 10-08-2008 12:33 PM
Work Offset Question Cartierusm Mach Software (ArtSoft software) 17 11-29-2007 03:50 PM
