Old 08-01-2011, 07:10 PM
samu's Avatar
samu is on a distinguished road
hardinge VMC1000 parameters
I have a hardinge vmc 1000 with Fanuc 0-MD control. I suspect that this machine is not well tuned. If somebody have the same machine, could you please send me your parameter backup. I would want to compare with mine.
I have problem with circular interpolation. Even a low feed rate or with a big radius, there is a big error. I have to put a different offset to each hole diameter i want to spin and it is problematic in contouring cause if i adjust offset to be correct in some radius, the straight section and the other radius are not in the tolerance.
Old 09-23-2011, 11:38 AM
Lewertek is on a distinguished road
Hello Samu,
I can help with that. You may know me already; I was the local (Quebec/Ontario) serviceman for Hardinge/Bridgeport from 2000-2010.
I am now freelance; see my site at LewerTek Inc. : CNC Machinery Repair Canada for contact info.
Need Help!- Hardinge VMC1000 with Fanuc O-MD orangelss Bridgeport and Hardinge Mills 3 11-01-2010 12:47 PM
hardinge vmc1000 samu Bridgeport and Hardinge Mills 3 05-11-2008 06:44 PM
Need Help!- vmc1000 heidenhain510 FLOATER1234 Bridgeport and Hardinge Mills 5 03-14-2008 06:51 AM
Upgrading a 2000 Hardinge VMC1000 fanuc omd sco999 Bridgeport and Hardinge Mills 2 04-14-2007 02:22 PM
Parameters on Cobra 42 Hardinge Niall Bridgeport and Hardinge Mills 0 07-16-2004 04:38 AM
