Old 07-28-2011, 11:25 PM
MetalicGlow is on a distinguished road
TC-22 with DX32 Went down big time.
My machine sat for 3 months. The last time I ran it, there were no issues.
I turn on the machine and it boots normally, loads the BMDC, press 7 to turn on drives, press 8 to home everything - no problems until I start pushing buttons:
The Tool Release Button is lit up green, but is non-responsive when pressed. There is no air line noise and can't feel anything mechanical moving. Dead as a door nail.
The + and - Buttons on the control are non-responsive when attempting to jog. However, the jog turn knob works.
The Run and Hold Buttons are non-responsive.
Speed and Feed Turn Knobs are non-responsive.
The spindle will start and run normally after entering the commands manually.
Current Status:
Here are the state of the LEDs on circuit boards (Which are all normal):
BMDC: Blinking Green/ Steady RED on D2 LED at the very corner of board
AUF: Blinking Red LED (D12)/ Steady Red LED (D11)
TLAUF: Blinking Red LED (D5)/ Steady Red LED (D4)
X, Y, Z Axis Boards: All 3 are Steady Green
I pulled the BMDC board and cleaned the contacts and reinstalled.
Checked continuity of all fuses.
I don't even know where to begin. Any suggestions would be greatly appreciated.
Old 07-30-2011, 10:16 AM
Moderator
machintek is on a distinguished road
Is power going to these switches? Do not have print in front of me but on a V2XT these run on 12 VDC from the logic power supply and if the CMOS battery leaks it takes out the 12VDC. I would imagine the TC-22 uses the AUF and 24 VDC. There are 2 airplane type pop out breakers behind the AUF. I have had these develop a high resistance and some things stopped working. I have to find a print to see what is common to these switches.
George
Old 07-31-2011, 08:53 PM
Machintek,
I replaced the CMOS battery a while back and it still looks brand new.
I could not find any breakers behind the AUF card, but there were two fuses underneath the card that I overlooked when frantically checking the ones across the top of the cabinet a few days ago. Sure enough one of them was blown. I replaced the blown fuse and the monster has risen.
Once again, you help proves once again to be invaluable. Thanks!
Need Help!- long time reader first time poster blu333 General Metalwork Discussion 0 02-21-2010 05:30 AM
Newbie- New to me 308 with DX32 Ranchero50 Bridgeport and Hardinge Mills 8 04-11-2008 11:12 AM
milling time (not to be confused with hammer time) barefoot0 G-Code Programing 4 05-02-2007 06:18 PM
X2 Conversion Time (shopping time) Micro Rotors Benchtop Machines 2 03-04-2007 11:11 AM
dx32 dnc Alan bailey Bridgeport and Hardinge Mills 9 11-06-2006 07:14 PM
