Old 07-25-2011, 04:55 AM
tomcannon is on a distinguished road
Bridgeport Interact 1 Jog Wheel Problem
Hi all, excuse my lack of knowledge as I am fairly new to the scene.
We had problems with the screen on the mill, so the whole Heidenhain T151 control box was sent off, fixed, and re-fitted. Now everything works fine and I had my first lesson with the machine having never used a CNC one before, however the jog wheel is completely inoperative. All manual control joysticks are fine, and before an electrician is called out I thought I would check to see if there is potetially an easy fix.
Many thanks,
TC
Old 07-25-2011, 07:21 AM
gus gus is offline
gus is on a distinguished road
there is a connector for the handwheel on the back of the control
Does handwheel mode come up?
Old 07-25-2011, 07:25 AM
Hi, if you push the handwheel button it does light up correctly, but no input, the other manual controls work fine though.
Problem- Bridgeport Interact 2 Series 2 Problem theo1 Bridgeport and Hardinge Mills 4 06-05-2011 06:53 AM
Bridgeport Interact 412 Tool Changer Problem RMARCH Bridgeport and Hardinge Mills 17 05-09-2011 10:57 AM
Need Help!- Bridgeport Interact 720 memory problem! FLjoyride Bridgeport and Hardinge Mills 5 10-28-2010 07:35 PM
Bridgeport Interact 24v DC reg problem Paul_Leoni Bridgeport and Hardinge Mills 3 11-14-2006 03:15 AM
Bridgeport Interact 1 MkII problem sparsrus Bridgeport and Hardinge Mills 13 05-02-2006 03:53 PM
