Old 07-21-2011, 03:35 AM
Phil J is on a distinguished road
Bridgeport VMC 560 problem
Hello
Have a problem with a Bridgeport VMC 560, TNC 370 control, Siemens 611 drives.
After powering up the machine & going through the start up sequence the ER unit does not power up. The 3 phase to the unit is ok but the 24v supply is missing. Have tried to trace back to the source of the 24v but without success, the circuit diagrams don't show this. Not sure at this point if the ER unit has failed or the 24v is the problem.
Can anyone help please?!
Thanks in advance
Phil
Old 07-21-2011, 09:35 AM
kongzai is on a distinguished road
Originally Posted by Phil J View Post
Hello
Thanks in advance
Phil
If you can't see a green light and a yellow light on the ER unit when machine powers up, the ER unit is definitely faulty.
Old 07-31-2011, 09:13 PM
FLjoyride is on a distinguished road
You should have two 24V power supplies in your electrical cabinet. Find them, and verify that they are working correctly. If you're having trouble, call Rick at heidenhain - 847-519-4858
Old 07-31-2011, 09:22 PM
I got two of these when my 24V power supplies went out (TNC2500b), they are great for sensitive equipment and have less 'ripple' than the specs required by heidenhain. Don't cheap out on the power supplies. I've been running these for 6 months.
FEAS GmbH - Netzteil PSUG243
They are less than the originals (impossible to find anyway) and better, completely sealed.
Old 10-28-2011, 08:41 PM
moldd is on a distinguished road
i had the same problem with a Heidenhain 410 (digital)
the power module of the simodrive was responsible. After repairing it twice at a local electronic repair shop, i exchanged it with a overhaulded one.
My simodrive is a digital model and the replasment cost wαs about 2000€
dimitris
Need Help!- Problem on Bridgeport VM 1000 dzcatic Bridgeport and Hardinge Mills 1 02-11-2011 10:28 PM
Problem- Bridgeport VMC 800 lubrication problem dmold Bridgeport and Hardinge Mills 3 11-15-2009 09:05 PM
Bridgeport 760 t16 encoder problem jke6113 Bridgeport and Hardinge Mills 1 09-28-2008 07:36 PM
Bridgeport Interact 24v DC reg problem Paul_Leoni Bridgeport and Hardinge Mills 3 11-14-2006 03:15 AM
Problem with Bridgeport backgear navets Bridgeport and Hardinge Mills 1 03-06-2006 01:29 PM
