I had a terrible accident with my spindle. I was facing a thin part of aluminium and when the 3" facemil began to exit the part, the part climb in the cutter an force down the cutter. The down force was so big that the drawbar wasn't strong enough to retain the cutter. The tool holder pass under the spindle key so it stop turning while the spindle is still running. Result: The tool holder and the spindle taper are burned whit big burrs. Only the top and the bottom of the spindle taper(cat 40 taper) is affected(about 1/2in each end). Is there something to do or spindle is dead? |
| Given the age of the mill and what happened after getting the taper reground I'd probably just pull the drawbar, chances are you will find cracked or broken bellville washers. Replace the whole stack, not just the broken ones. Make sure you put them back on the drawbar in the same order and the nut is tightened down just the same as it was before. |
| Need Help!- How do i disassemble a Prolight 1000 spindle | dspicguy | General Metal Working Machines | 0 | 01-29-2011 11:36 AM |
| Used BP, Y Axis must by worn out in the center | Wade | Bridgeport and Hardinge Mills | 8 | 03-30-2010 08:19 PM |
| Arrow 1000 spindle trouble | raygun | Cincinnati CNC | 3 | 03-02-2009 09:32 PM |
| with a Dover air Spindle, DMM-1000 drive connections | DiamondGirl | Servo Motors and Drives | 1 | 02-18-2008 07:56 PM |
| STAR 067-30 bushing, how can i see if it is worn out ? | vroemm | Linear and Rotary Motion | 0 | 06-26-2006 09:07 AM |
