Old 07-13-2011, 11:08 AM
wahidbashir is on a distinguished road
FANUC 21i Serial Spindle RPM
Frndz,
I have a turning machine with FANUC 21i with serial spindle A06B-6112-H006.
Its commanded speed and actual displayed speed always differ by 20%.
measured speed is greater.
Is there any way to calibrate it by using spindle parameters.
Old 07-13-2011, 11:46 AM
underthetire is on a distinguished road
Are you even supposed to have A 21i control over there? Just askin...
Old 07-14-2011, 08:31 AM
Just supposed it may be 18iT. If u have any idea then write it
Old 07-14-2011, 09:31 AM
Jim Green is on a distinguished road
Is the speed off by the same amount in reverse rotation?
Old 07-14-2011, 10:05 AM
Yes Dear,
With same results.
By the way what would you suggest if it is different on reverse
Old 09-23-2011, 11:59 AM
Lewertek is on a distinguished road
Adjusting Fanuc 18/21 spindle speed
I do not recall exactly which parameter, but it is related to either the maximum spindle speed ,(3741 or 3772) or maximum motor speed(4020) (I would try 4020 first), if I recall correctly. Record the original values before changing anything! You should be able to get it set within a few RPM of the programmed speed by trial and error.
Hope this helps a few people out there.
Need Help!- fanuc 21it serial spindle bennyboy78 Fanuc 0 07-01-2010 10:49 AM
Problem- spindle serial link error 750 Fanuc 21i-MB Abdul Haq Fanuc 0 05-13-2008 05:59 AM
Need Help!- spindle serial link error 750 Fanuc 21i Abdul Haq Fanuc 0 05-13-2008 01:48 AM
help!: spindle serial link error emonje Fanuc 1 05-08-2008 10:07 PM
How to setting fanuc serial spindle parameter? ning Fanuc 1 10-30-2005 02:38 PM
