I was adjusting my tapping deceleration and also looking over some other parameters in the technical manual when I saw the X,Y,Z and 4th axis automatic lubrication parameters. I have TNC2500 control and was wondering what other people are using for these values. The range is 0...65535 (in units of 65536 um). I'm assuming it is micro meters? All of mine are set to 0. |
| Parameters related to lubrication system: 4110.5 - 25000 4110.6 - 200 4110.7 - 210 4120.0 - 3 And the unit is not um. 0...65535 is in the unit of PLC cycle, 1 cycle = 24msec. Parameters above will provide you with 30minute of lubrication cycle, 5 sec of lubrication On time, and 4.8 sec of time-out limit for lubrication pressure. |
| I have parameter 4060.0 as X, 4060.1 as Y, 4060.2 as Z, and 4060.3 as 4th axis under the automatic lubrication section in the tech manual. 4110.5,6,7,8 etc. are for PLC programmed durations for timers 0-47, durations of 24 in ms. I'm not sure where to find what each timer does.. |
| Need Help!- bridgeport interact 1 lost parameters | thomasmc | Bridgeport and Hardinge Mills | 9 | 03-29-2012 12:44 AM |
| Bridgeport Interact 520/Heidenhain TNC 155 initial parameters | jeromir | Bridgeport and Hardinge Mills | 10 | 08-30-2010 05:01 AM |
| Need Help!- Bridgeport Interact 720 parameters | M.G.Machinist | Bridgeport and Hardinge Mills | 3 | 01-07-2010 06:04 PM |
| Need Help!- Bridgeport 1000/22 TNC370 Lube Cycle Parameters | BetaBob | Bridgeport and Hardinge Mills | 5 | 07-07-2009 12:07 AM |
| Bridgeport Interact 412/Heidenhain TNC 250 initial parameters | pedrow | Bridgeport and Hardinge Mills | 11 | 04-04-2007 12:09 AM |
