Old 06-29-2011, 07:23 PM
Korellibopper is on a distinguished road
NEED BRIDGEPORT SERIES ONE EZ TRAK WIRING DIAGRAM
I PLUGGED IN THE SERIAL CABLE FROM THE EZTRAK CONTROLLER TO THE MAIN BOX AND SOMETHING BLEW. MADE A LOUD BANG. NOW I HAVE NO IDEA HOW TO FIX IT THE FUSE THAT BLEW JUST KEEPS BLOWING.
ANY IDEAS
THANKS
Old 06-29-2011, 10:09 PM
n174k is on a distinguished road
Korellibopper
This should be what you are looking for.
Del
Old 07-01-2011, 06:30 PM
Talking
ill show the electrician it looks grat to me though thanks a million
Old 07-04-2011, 12:14 AM
ppascuzzi is on a distinguished road
I f those prints don't match let us know. There were a number of different versions of the EZtrack control wired by a number of different companies for bridgeport...all of them had different prints. Does the machine have a facotry flatpanel lcd monitor (not an aftermarket one)? Where is the floppy drive located on the machine?
Old 07-26-2011, 02:40 PM
the machine is a Bridgeport Rapid 8 model.
Old 07-27-2011, 05:51 PM
No rapid 8 is the power drawbar. If the ez trak prints that were posted do not match your mill you will have to help identify which version of eztrak you have. Rather than going off on a tangent it would be easier if you tried to answer the questions I asked in the last post. The other option is to forget abouthaving an electrician look at it and call in a cnc technician who is familiar with eztraks and likely has the prints already.
Old 07-28-2011, 04:27 PM
Its been fixed the lube pump was causing the fault. To answer your questions there is no lcd or floppy drive on this machine. the only label is ez-trak on the control box. This machine is about 27 years old.
Old 12-03-2011, 11:01 PM
Fusioncraft is on a distinguished road
Question
Do these apply to an EZ-Trak DX 2000 with 3-axis? Also, do you have access to a service manual for this model? thanks.
Old 12-04-2011, 10:18 AM
Moderator
machintek is on a distinguished road
Probably a EZTRAK by Southwestern industries.
George
Old 12-04-2011, 10:30 AM
Where would I be able to find a service manual for a Bridgeport EZ-Trak DX (built in 2000)?
Need Help!- Series 1 Wiring diagram TarHeelTom Bridgeport and Hardinge Mills 11 09-06-2011 12:00 AM
Need Help!- 1997 Bridgeport EZ-TRAK SERIES 1 DX tdr1985 Bridgeport and Hardinge Mills 4 10-22-2010 09:43 AM
Need Help!- Serial wiring for Bridgeport EZ TRAK SX brussell Controller & Computer Solutions 0 01-09-2009 01:33 PM
Bridgeport Retrofit Wiring Diagram UKRobotics General Electronics Discussion 0 09-18-2006 04:39 AM
system Wiring diagram, BMI Trak W/LCD needed bsllc Bridgeport and Hardinge Mills 5 02-17-2006 03:18 PM
