Old 06-25-2011, 12:15 PM
fjbart70 is on a distinguished road
contoured path is faceted?
I have cut a contoured path with a large radius (~8") on teh side of a part using mastercam x5. IT was cut using a .375" end mill on z bridgeport discovery CNC with a DX32 controller.
Instead of getting a smooth contour it cuts with a faceted or segmented contour. Still looks nice, but not what I expected. I have attached a picture of the part.
Not sure if this is a setting in mastercam that is causing this of if it is inherent to the machine?
Any advice is appreciated,
Old 06-26-2011, 09:55 AM
KevinV_MEI is on a distinguished road
Can you post a portion of the code?
mastercam contour faceted cut fjbart70 Mastercam 11 06-28-2011 03:23 PM
Need Help!- FACETED ELLIPSE cncstephen Mastercam 12 06-15-2011 04:23 AM
Flat Sketch to Contoured Cut? Vrogy Solidworks 15 09-07-2007 06:28 AM
Scripting a constant offset curve over a contoured surface? Splint Rhino 3D 11 03-11-2007 04:35 AM
Wire cutting big faceted shapes terraswarm CNC Wire Foam Cutter Machines 5 02-10-2005 04:53 PM
