Old 06-23-2011, 01:55 PM
dek dek is offline
dek is on a distinguished road
Unhappy error44 check pocket
Error message 44 check pocket has come up on the screen (ITNC530 bridgeport 5axis) i have gone into error messages where it says you can cancel it which i have done , but it still comes back but the machine still runs with message still up .Anybody have any suggestions please
Old 06-23-2011, 05:22 PM
gus gus is offline
gus is on a distinguished road
so obviously a 1957 Monarch right?
info please
did you accidentally program to an empty tool pocket? Or does it check all tool pockets and want to see them full?
Old 06-24-2011, 10:53 AM
dek dek is offline
Ive only just started in this firm so i dont know to much of the history of this machine but i know its not a 1957 monarch ,i have spoken to the chap that used to work on this machine and they had a problem in the past with the toolchanger.He has looked at it with me and although i am picking up tool 31 it is taking it from position 30 ,this was like this when i started but only now the error is coming up.
Old 06-24-2011, 07:51 PM
gus gus is offline
You realize that no one can help you until you tell us what machine it 'is'
Go learn some things and then come back
Old 06-24-2011, 09:35 PM
ppascuzzi is on a distinguished road
Since it is an iTNC530 control you have one of the XP3 or XR models. That tool #31 is in pocket #30 doesn't matter, there is a pocket table that keeps track of what tools are in which pockets and it is usual for tools to be place back into a different pocket then they were taken from.
I don't have an error code list for a XP3/XR with a Heidenhain control however I do know there is no sensor to tell if a tool is in a pocket or not. The only sensors that deal with pockets are the ones that check if the pocket is up or down. Check to make sure the pocket is going all the way back up after the tool change and is not slow on making the up sensor. You can also program it so the pocket stays down after the tool change and see if that gets rid of the alarm. (open up your Hardinge operators manual and it will tell you how to do this)
If that all is okay check the pocket table (the Heidenhain operators manual will tell you how to do this) and see what the control thinks is stored in that pocket
Old 06-25-2011, 01:10 PM
kjtdouglas is on a distinguished road
I have 3 XR's with the 530 control(only 3 axis tho). I don't know what error message comes up but we get problems with fine ally swarf getting in the grease around the pockets. We have to take the covers off and clean everything then regrease and we are good to go for another few months.
Best regards ---- Kevin Douglas
Old 06-26-2011, 01:46 PM
That's likely your problem. The chips are preventing the pocket from going all the way up or are setting off the down sensor. If it is not possible to shield the pockets from the swarf you might be able to set up an air blast to keep the chips blown out of the area. Otherwise you'll just have to make it part of your pm's to clean these out.
While we are talking about pm's, the XR's and XP3's have another essential part of pm's that does not show up in the manuals. When you grease the X axis linear guides you will have the way cover pulled back. While you have this cover back look under the ballscrew/motor coupling and also in about the middle of the casting. In the casting there will be 2 drain holes about 1/2 inch in diameter, these holes have a tendency to fill up with chips and allow coolant to fill the pocket around the ballscrew. Make sure these holes are clear and coolant is not standing in this pocket. This has been the main cause of x axis ballscrew end bearings and ball screw replacement that I have seen on these machines. If you are cutting anything with large light chips (like aluminum) they are more likely to plug up.
Old 06-26-2011, 03:23 PM
Thanks for the heads up on this. I will inform my guys to check this out.
Old 06-27-2011, 02:46 PM
dek dek is offline
I have now started to have is the right tool in spindle coming up all the time,and wont change tool until i press the green button.havent had time to look at tool changer yet.Ive looked in the user manual but i cant seem to find how to keep tool down
Old 06-27-2011, 02:53 PM
dek dek is offline
  #11   Ban this user!
Old 06-27-2011, 10:53 PM
Look in the tool table section. The Bridgeport/hardinge user manual is only about 50 pages.
  #12   Ban this user!
Old 06-29-2011, 02:25 PM
dek dek is offline
Smile
i turned isolator off left for 10 mins started machine again . went to pick up another tool, screen said unclamp tool so i did and then reclamped and called tool again, same message came up went into tool table tool was in there then i saw another button tool log or something, the tool that was in spindle was not there so in the tool number line i typed in what it was i.e. 8m/mball entered now everything is working fine .
Thanks for everyones help i really needed some advice.
pocket manmardam Mastercam 5 04-06-2011 11:40 AM
Need Help!- Pocket help fourwheeler BobCad-Cam 8 11-23-2009 06:53 PM
Better Way To Pocket In X2? Mastercam User Mastercam 24 12-06-2007 08:44 AM
pocket pc DONNYBRASS General Metalwork Discussion 0 11-18-2007 03:02 PM
Spell check it out!!! I just noticed CNCzone now has spell check! HayTay CNCzone Club House 3 01-19-2007 07:59 AM
