Old 06-23-2011, 06:53 AM
RMARCH's Avatar
RMARCH is on a distinguished road
Bridgeport Interact 412 Spindle Orientation ?
I am trying to set my Spindle Orientation for a tool change.
My Manual says i need to fit a test switch ( set open ) between wires red/blue & Green/red on 17CR. So can i jump the 2 wires together or do i need some kind of switch ?
When I do a M19 or a M6 my spindle spins but it doesn't find the spindle orientation for a tool change. The spindle will stop but it takes a while and stops at random locations.
Thanks for your help !!
Ray
Old 06-23-2011, 07:13 AM
gus gus is offline
gus is on a distinguished road
Did you solve the last problem?
sure sounds like something is up with the spindle drive
Old 06-23-2011, 07:23 AM
RMARCH's Avatar
Hi Gus,
The Spindle Orientation was working correctly but i messed it up somehow trying to fix my other problem ( Axis PSU fault.) I tried jumping the Red/Blue & Green/Red wires but the spindle keep turning.
I guess it might be time for the professionals.
I think you may be right. Something is wrong with the spindle drive.
Problem- Bridgeport TC3 spindle orientation SierraDan Bridgeport and Hardinge Mills 0 10-03-2010 09:29 PM
Top spindle I.D. on a Bridgeport Series II Interact 2 ichudov Bridgeport and Hardinge Mills 0 08-11-2010 07:49 AM
Bridgeport Interact Spindle problems hansdie Bridgeport and Hardinge Mills 8 11-22-2008 06:30 AM
Looking for Bridgeport Interact 412 Spindle 10K RMARCH Bridgeport and Hardinge Mills 1 03-12-2008 11:09 AM
Spindle Reverse on a Bridgeport Interact? UKRobotics Bridgeport and Hardinge Mills 29 10-27-2007 08:04 AM
