| I am having a lot of trouble getting the tools properly registered in the control. I cannot get the tools from the spindle to the tool carusel. The machine was purchased used and it was just powered up. The machine is in great shape, but nobody knows anything about it here. Please help, the control offers 2 ways to load tool offsets, one through a central tool file which is program 0 and the second is individually, not sure which way works best but I am stuck... |
| With the changer you really need to use the tool table using conversational, write a program that has lines such as: TOOL CALL 1 S100 Z IZ.001 F2000 M06 run the program and see if the machine goes and gets the correct tool change the tool number and repeat. if it acts correctly, you need to load the tools one by one and then define them in the tool table, you should be ok |
Gus, Thanks, that worked. How does the machine know where tool 0 is? does it automatically reference from the spindle z ? As I understand it, since that is z 0 then all my tools will have a + on the z length? It is a bit confusing. |
| From what I can tell tool #0 is imaginary. Luckily my machines previous owner had etched the tool number onto each fork on the carousel so I know which one is which. It starts with #1 then goes up to 20 going clockwise (for me on my Interact 720). There are perameter settings to either use a central tool program (program 0) or specify tools within each program. I have mine set up to use the central tool program, I just can't figure out how to get program 0 into inch mode so I have to convert my tool diameters and lengths to mm. |
| Tags |
| heidenhain 2500b |
| Need Help!- VMC760, Hiedenhain 2500B, ISO - in drip feed tool change | rmarchjr | Bridgeport and Hardinge Mills | 3 | 12-10-2010 10:07 AM |
| Heidenhain 2500B help | chpbrkr | Bridgeport and Hardinge Mills | 3 | 10-25-2010 08:27 PM |
| Need Help!- Heidenhain TNC 2500B | Erik1000 | Bridgeport and Hardinge Mills | 6 | 04-21-2010 07:15 AM |
| Bridgeport VMC 1000 Heidenhain TNC 2500B | racerdog | Bridgeport and Hardinge Mills | 8 | 12-16-2007 05:37 AM |
| bridgeport series 11 interact 11 hiedenhain tnc 2500 control | blackpalm | Bridgeport and Hardinge Mills | 0 | 09-19-2007 11:21 PM |
