Tried writing both iso and conversational programs to no avail. Conv. BEGIN PGM 1 INCH TOOL CALL 5 Z S300 L R F M06 G53 P01+1 L X+11.6877 Y+.7716 R F MAX M03 CYCL DEF 2.0 TAPPING CYCL DEF 2.1 SET UP -0.1 CYCL DEF 2.2 DEPTH -0.875 CYCL DEF 2.3 DWELL 0. CYCL DEF 2.4 476 L X-8.398 Y-5.8988 R0 F MAX M03 Getting an error at cycl def 2.4. feed rate. Changed it to several values from 476(0.0625 pitch per inch X 25.4 x 300 rpm) Just struck me, maybe it needs to be; CYCL DEF 2.4 FEED)476 Edit; I edited the program adding FEED, same results/error. Or ISO ; N1 G00 G90 Z0. M91 ; 3/8-16 TAPRH N2 T5 G17 S713 N3 M06 N4 G53 P01+1 N5 G00 G90 G40 X-8.398 Y-5.8988 M03 N6 G84 P01 .125 P02 -.875 P03 0 P04 1131.8875 N7 Z+2 M08 N8 Z+0 M99 Error on N6. No other feedback. Could be decimal in feed rate? Edit; fiddled with speed and feed to get a close even numbers with same error. Anyone have working code in either iso or conv for rigid tapping I can compare to what I'm doing to get some headway on this? Kevin. Last edited by KevinV_MEI; 06-18-2011 at 11:56 AM. |
| As Gus said the cycle is wrong. I am not at work either but I think its Cycle 17 BEGIN PGM 1 INCH TOOL CALL 5 Z S300 M06 CYCL DEF 17.0 RIGIDTAPPING CYCL DEF 17.1 SET UP+0.1 CYCL DEF 2.2 DEPTH-0.875 CYCL DEF 2.3 F0.0625 L X+11.6877 Y+.7716 R0 F MAX M03 Z+0.1 FMAX M99 L X-8.398 Y-5.8988 F MAX M99 I think thats about right
__________________ Best regards ---- Kevin Douglas |
| Thanks guys. Yes the conversational was wrong. I did get it to work in iso. Have to edit programs by hand but the following line works great, G85 P01(start above datum value) P02(depth from datum, incremental) P03+(pitch in decimal inch) or G85 P01+0.1 P02-1.0 P03+0.0625 Once I started typing G85 instead of G84 on the controller the help dialog box/graphics popped with all of the correct parameters and there proper syntax. This controller is so advanced. Wish i had time for formal training. K. |
| I don't remember how close your controller is to mine. Maybe this will work on yours. 118 L R F M03 119 CALL LBL 1 REP 120 CALL LBL 2 REP 121 CYCL DEF 17.0 RIGID TAPPING 122 CYCL DEF 17.1 SET UP-0.1 123 CYCL DEF 17.2 DEPTH -0.25 124 CYCL DEF 17.3 PITCH +0.031 125 CALL LBL 3 REP 126 CALL LBL 1 REP 127 CYCL DEF 7.0 DATUM SHIFT 128 CYCL DEF 7.1 X-2.75 129 CALL LBL 2 REP 130 CYCL DEF 17.0 RIGID TAPPING 131 CYCL DEF 17.1 SET UP-0.1 132 CYCL DEF 17.2 DEPTH -0.25 133 CYCL DEF 17.3 PITCH +0.031 134 CYCL CALL M 135 CALL LBL 3 REP 136 CALL LBL 1 REP 137 CYCL DEF 7.0 DATUM SHIFT 138 CYCL DEF 7.1 X-5.5 139 CALL LBL 2 REP 140 CYCL DEF 17.0 RIGID TAPPING 141 CYCL DEF 17.1 SET UP-0.1 142 CYCL DEF 17.2 DEPTH -0.25 143 CYCL DEF 17.3 PITCH +0.031 144 CYCL CALL M 145 CALL LBL 3 REP 146 CALL LBL 1 REP 147 CYCL DEF 7.0 DATUM SHIFT 148 CYCL DEF 7.1 X+7.0603 149 CYCL DEF 7.2 Y-0.0008 150 CALL LBL 4 REP 151 CYCL DEF 17.0 RIGID TAPPING 152 CYCL DEF 17.1 SET UP-0.1 153 CYCL DEF 17.2 DEPTH -0.25 154 CYCL DEF 17.3 PITCH +0.031 155 CYCL CALL M 156 CALL LBL 5 REP 157 CALL LBL 1 REP 158 CYCL DEF 7.0 DATUM SHIFT 159 CYCL DEF 7.1 X+9.8103 160 CYCL DEF 7.2 Y-0.0008 161 CALL LBL 4 REP 162 CYCL DEF 17.0 RIGID TAPPING 163 CYCL DEF 17.1 SET UP-0.1 164 CYCL DEF 17.2 DEPTH -0.25 165 CYCL DEF 17.3 PITCH +0.031 166 CYCL CALL M 167 CALL LBL 5 REP 168 CALL LBL 1 REP 169 CYCL DEF 7.0 DATUM SHIFT 170 CYCL DEF 7.1 X+12.5603 171 CYCL DEF 7.2 Y-0.0008 172 CALL LBL 4 REP 173 CYCL DEF 17.0 RIGID TAPPING 174 CYCL DEF 17.1 SET UP-0.1 175 CYCL DEF 17.2 DEPTH -0.25 176 CYCL DEF 17.3 PITCH +0.031 177 CYCL CALL M 178 CALL LBL 5 REP 179 L X-6.25 Y+1.5 R F MAX M25 180 END PGM 436 INCH
__________________ Still working in the "D". |
| It's in conversational so it's easy to check. Start programming it by hand at the machine and the controller will tell you what it needs. They are all probably a little different.
| tapping on a mini mill without rigid tapping??? | mls | Haas Mills | 13 | 07-03-2009 06:43 PM |
| Tapping with the Tormach Tapping Head | bobs_charger | Tormach PCNC | 0 | 04-24-2009 04:08 PM |
| Tapping head or rigid tapping | Gregory_C | Syil Products | 2 | 10-18-2008 12:49 AM |
| Rigid tapping or tapping head | wildcat | Industrial Hobbies (Support forum) | 7 | 09-24-2006 12:08 PM |
| tapping head vs hand/cordless tapping machine.... | InspirationTool | General Metal Working Machines | 6 | 09-12-2005 08:10 PM |
