Old 06-12-2011, 12:59 AM
eckolaw is on a distinguished road
bridgeport series II work offsets
I have a quick question and you guys are so knowledgable on here. I have try searching here for the answer but have not found it.
I have a Bridgeport Series II R2E4 Boss 8 and was wondering if it can handle work offsets (G54, G55, ....). I have two vices and would love to utilize them both. I am working with mastercam and bobcad if that helps in any way.
Thank you in advance!
Old 06-12-2011, 06:59 AM
John Bennett is on a distinguished road
R2E4 G54
Note, I have a R2E3
G54 is not available on the Boss 8 control, one alternative would be to use the G97 code (instructions attached) The other method since you are using a cad/cam program would be to do an array on the drawing to correspond to you fixtures.(mastercam ...Xform..Rectangular array ....)
Old 06-13-2011, 09:06 AM
Thank you very much. Seems like it would be easier to just measure my vice positions with an edge finder after squaring them up and use array as you said. I will try both just so I know how to do both.
Thank you for the information and perfect answer!!
Work Offsets RMT Mach Mill 14 12-14-2008 09:49 AM
how do you set G54 thru G59 work offsets? Barney Fanuc 10 01-07-2007 03:02 PM
Will this VFD work for my Bridgeport 2hp series 2 CNC jstew0903 Phase Converters and VFD 3 05-23-2006 11:23 PM
Bridgeport VMC 500 XP1 - Work Offsets cadcamjohn Bridgeport and Hardinge Mills 3 05-03-2006 04:31 PM
Will these ametek motors work for Servos on my Bridgeport Series 2 mill? jstew0903 Servo Motors and Drives 3 10-26-2005 05:00 PM
