Old 06-11-2011, 04:33 PM
FugginZukin is on a distinguished road
BP Explorer X-26 prob. after DOM replacement.
Hello Folks,
I hope you guys can help me out here. Machine went down due to a blown Disk on Module. Here are the chain of events:
-DOM took a dump; bought a new one.
-Uploaded OE software DOS 5.0
-Went to upload OEM software (disk that came with machine) only to find it was blank, uh oh...
-Went to V2XT yahoo group and downloaded same version BOSS software and installed on machine.
-Software works, all is well, machine checks out fine, except:
When homing the axis' I get an error that says, "Error in reading disk!! Hit any key" during the homing sequence. Once homing is complete, the axis numbers are all fubar. Z homes at 10.0000 and the X and Y are off also. X servo motor now humms louder than it used to. Hmm...parameters?
Now out of the four install options when loading the software one could select V2XT, 308, Explorer, etc. I selected explorer; however, I believe the parameters for this option may be different than for the "Explorer X-26" as the standard Explorer has less travel. Does this sound plausible for the homing issue at least?
Does anyone have a parameter file for the X-26 they would like to share?
Any thoughts on how to fix this issue?
Your help is greatly appreciated. Thank you!
Old 06-14-2011, 10:57 AM
Well, I haven't gotten the software issue fixed even after modifying the Explorer I param file to suit the X-26. Along the way I noticed some other issues that have also popped up in this fiasco.
I am also getting:
-Low pressure alarm (yet there is 85 psi and solenoid works).
-Cannot control spindle speed yet it will still start (due to low psi alarm).
-Spindle stop button on head does not work.
-AUF light D11 glows bright red while light D12 blinks on-and-off bright red.
Is my AUF dead?
Thanks.
why y axis prob +or-.0005 Servo Motors and Drives 0 02-15-2011 06:30 PM
Bridgeport Explorer (V2XT, DX-32) Motherboard Replacement FugginZukin Bridgeport and Hardinge Mills 9 01-10-2011 01:15 PM
VFD METER PROB SIGNMAD Excitech routers 3 11-12-2008 11:39 PM
sheet cam prob fastimes SheetCam 0 07-28-2006 09:11 PM
Multicam 4800 prob peterklos CNC Machining Centers 0 02-26-2004 10:19 PM
