Old 09-06-2005, 11:06 AM
DustyL is on a distinguished road
Question heidenhain help
can anybody tell me how to and is it possible to dripfeed long programs to a tnc151 control?
Old 09-06-2005, 06:54 PM
Moderator
machintek is on a distinguished road
There is a BPT technical bulletin on communications to a TNC control. I have to find it.
Just in case it exceeds the 500 KB limit here, what is your email?
George
Old 09-06-2005, 09:40 PM
Moderator
I found technical bulletin 6. It is about 2.5 MB long.
George
Old 09-07-2005, 05:19 AM
thanx machintek.
Old 09-07-2005, 06:54 AM
Moderator
Done. See if this helps.
Heidenhain can also be called. They are just outside of Chicago.
George
Old 10-30-2005, 12:40 AM
Builder is on a distinguished road
machintek
Do you think I could get a copy of this bulletin also?
Thanks Tony
Old 10-30-2005, 10:09 AM
awemawson is on a distinguished road
Heidenhain Help: Dripfeeding TNC151
Download TNC REMO from Heidenhain's site - set it up and run TNCSERVER
Make up a cable from 25way TNC151B to 9 way PC as follows:
(25way TNC) <9 way PC>
(2) - <2>
(3) - <3>
(4) - <8>
(5) - <7>
(6) - <4>
(7) - <5>
(20) - <6>
The TNC RS232 interface can exist in three modes - "EXT", "ME", and "FE" selected via the 'MOD' key - it should be in "FE"
File names & extensions ARE important in block mode transmission. 123.H = program 123 in Heidenhain conversational code and 123.I is program 123 in ISO-Gcode
When set up like the above it will work - it took me ages to sort it but now all is reliable.
AWEM
Andrew Mawson
East Sussex, UK
Old 10-30-2005, 07:12 PM
Moderator
Tony, if you still need this tech bulletin, give me an email address.
George
Old 10-30-2005, 08:28 PM
machintek, sorry about that. It's tonykutscher@optonline.net
Old 10-31-2005, 02:39 PM
pjeran is on a distinguished road
George,
Could you send me a copy of the tech note. Now that the mill is up and running it is time to get it connected.
My e-mail is paul(dot)jeran(at)hp(dot)com
Thanks,
Paul
Old 11-01-2005, 12:37 PM
Moderator
Tech Bulletin 6 sent to both of you.
George
