Old 06-08-2011, 02:01 AM
ccoleman is on a distinguished road
R2E3 4 wires in servos
Hi all,
I just found that the servos on my R2E3 have 4 wires. There are the 2 black and red heavier gauge wires that you'd expect, but then there are 2, maybe 18 gauge, black and red wires that are connected to a series of, what look like brushes, behind the bei encoder housing.
What are those extra wires and should I hook them up?
Thanks,
Chris
Old 06-08-2011, 07:17 AM
Moderator
machintek is on a distinguished road
Velocity Feedback loop (tach) is what they are.
George
Old 06-08-2011, 08:47 AM
Al_The_Man's Avatar
What drive are you hooking them up to, if using current drives in torque mode you do not need the tach, I usually take the brushes out also.
Old 06-08-2011, 11:48 AM
Ah, thank you.
I'm going to use the Dugong's on x, y and a 302v on the z. If I can take out those brushes it ought to make it a little easier to mount the new encoders.
Thanks,
Chris
help with wires linkintiger DIY-CNC Router Table Machines 15 02-24-2011 09:00 PM
the encoders' wires itself Khaled.Hosam Servo Motors and Drives 6 11-09-2010 06:16 PM
need help id 8 wires 15mgtar Stepper Motors and Drives 6 07-30-2009 12:53 AM
What wires to use? studysession DIY-CNC Router Table Machines 2 02-21-2007 01:02 PM
Best way to keep wires out of the way CuttersCov DIY-CNC Router Table Machines 3 11-02-2006 08:40 PM
