Old 06-06-2011, 09:10 AM
castle machine is on a distinguished road
Bridgeport xv710 Stop Postion
hardinge bridgport xv710. Keep losing spindle stop position. Spindle stopping at random positions, has anybody had this problem before?
Old 06-24-2011, 09:55 PM
ppascuzzi is on a distinguished road
Both the Siemens and the Fanuc versions used an encoder mounted on the motor for positioning, they also used a prox sensor that looks for a bolt on the spindle. A bad prox sensor would more likely cause no stopping at all. Given that it is a "random" stopping check 1) belts and pulleys to make sure nothing is slipping 2) coupling of encoder to motor to make sure nothing is slipping 3) encoder itself maybe bad (sometimes the disk breaks free of the shaft and this allows it to move some, it it is only slightly free it may only be noticable when positioning)
Problem- 'y' postion error CNCSIS Machine Problems, Solutions , Wireless DNC, serial port 0 03-05-2011 01:05 PM
Bridgeport Discovery 308 SX 15 Emergency stop error gopherxx Bridgeport and Hardinge Mills 1 11-29-2010 10:51 AM
Need Help!- Bridgeport EZ Trak emergency stop problem Craiga Bridgeport and Hardinge Mills 2 10-18-2009 11:56 AM
CNC Newbie buying XV710; Need Help!! winterhammer Bridgeport and Hardinge Mills 0 07-02-2008 03:18 PM
Bridgeport spindle brake - how fast should it stop? swarf_rat Bridgeport and Hardinge Mills 5 07-01-2007 01:11 AM
