A replacement spindle assembly. It will slide right in after you remove the setscrew at the rear of the quill and unscrew the nose piece. Knock the old one out with a broom stick from the top. Note that CNC spindle are longer than standard spindles because of the ball screw for the Z axis.
George
LinkBack URL
About LinkBacks
