Old 05-29-2011, 04:08 AM
paulvidgen is on a distinguished road
Interact 1 ser 1 TNC145
HI All
Iam a bit new to all is!!
we have an old Bridgeport ser 1 with the TNC145 control.
it orininaly worked ok, it was moved to another position and then not used for some time, perhaps a year.
when we powered it up it comes up with the usual start up screen and asks you travel over the zero points for the X Y & Z axies.
this is as far as you can get, nothing else on the machine will work, you can press the power up and cycle buttons but nothing happens.
I am suspicious that it has lost the paramiters out of the control unit.
does anyone know if this is what happens if the paramiters are lost and what i can do to check.
i rearly only want to use it to get some CNC experience, i know nothing about the machine but we do run a Torchmate CNC profile cuttter so we are not completly new to cnc machines.
I would apriciate an help please
Old 05-29-2011, 05:08 AM
awemawson is on a distinguished road
I think if it had lost all its parameters it would come up speaking German. Is the air supply reconnected after the move? Is the lube oil level high enough?
Andrew Mawson
East Sussex, UK
Old 05-29-2011, 05:44 AM
Hi
Yes the air was conected an on, and the lubricator is full.
can i check to see the paramiters are ok.
PV
Old 05-29-2011, 06:57 AM
gus gus is offline
gus is on a distinguished road
metric mode
95148
you did not lose parameters
you have a failure in the EMO string
lube level
limit switches
Old 05-29-2011, 11:36 AM
gus
you are correct i went into the peramiters they are all there
please can explain in a bit mor detail
can i override the lube level sensor?
how can i test the limit swiches?
dont understand EMO String!
Old 05-29-2011, 12:20 PM
gus gus is offline
somewhere in here someone posted a wiring diagram for a similar machine.
first you should download your parameters to your pc[and here to the heidenhain parameter thread if they are unique]
First, are any of the axis at or near their limits? If the oil is not FULL then this is your first place to look
Old 05-29-2011, 01:21 PM
Gus
none of the axis are near the limits, the oil in the res is about 1" down, i will go through and write down the peramiter list when i get a min.
i have now found the maintenance book, i will see if has a wiring diagram.
PV
Old 05-29-2011, 02:10 PM
mark562 is on a distinguished road
paulvidgen, One more thing you should try before spending the time chasing wires. Did you remember to energize the axis drives? (yellow button at the top left). Once you press this button it will move to each axis HOME point every time the CYCLE START button is pushed.
Hope this helps
Mark
Old 05-29-2011, 03:14 PM
Yes, acording to the book power enable button, the top one( green ) should energise the axis circuits and each time the cycle start buton is pushed it should move over each home point.
press what you like it does nothing.
PV
Old 05-30-2011, 02:11 PM
gridley51 is on a distinguished road
Check the feed overide is not turned down.
  #11   Ban this user!
Old 05-30-2011, 02:16 PM
Tried that.
still the same
  #12   Ban this user!
Old 05-30-2011, 04:35 PM
When you`re on the ref screen does it show a feedrate at the bottom of the screen?
When you press the cycle start button to reference the first axis does an asterisk appear
on the screen?
Tags
bridgeport 1, heidenhain, tnc145
TNC145 ovals? Mike Woo Bridgeport and Hardinge Mills 4 11-05-2009 09:40 PM
Need Help!- How do I adjust the tool changer height parameter on a TNC145 (Interact 412) Skin Bridgeport and Hardinge Mills 3 05-27-2009 07:16 PM
Problem- Interact / TNC145 buttons not working Mike Woo Bridgeport and Hardinge Mills 3 04-29-2009 07:29 AM
Problem- interact tnc145 bigbaz Bridgeport and Hardinge Mills 6 02-02-2008 10:19 AM
bridgeport 2/heidenhain tnc145 Dar Bridgeport and Hardinge Mills 4 03-19-2007 08:05 PM
