My cnc will except a program when I 1st turn it on. I may be able to load 1 or 2 more in the morning but after running it steady for a few hours the control will just keep erroring out and will not even show the * to send the program. Just keeps erroring out every time. Has anyone ever had this problem and if so where to look or test for it. I have replaced all the communication wires thining it may be something easy but the problem is still there. Can anyone help thanks Stan |
| I have been using the same computer and Bobcad software to load into the machine for the past 4 years. Never had this issue before. I have the setup using 4 wires for communication. I only send the prog. to the machine and make any edits in the software then reload. the settings are all the same as when I first set this up, but i did try to change them to see if it made a differance. No luck. Thanks for the reply |
| Sounds like a thermal issue. Comm is through the EAF board. What is the status of the single green LED on the board. What are the voltages of the 2 logic power supplies (one on the door to the EAF and one in the wireway to the EMC). Are your fans running? George
| Need Help!- Need help with R2E3 problem. | Revshift | Bridgeport and Hardinge Mills | 27 | 12-02-2010 11:14 AM |
| Newbie- 1987 bport r2e3 computer problem | jerry whitworth | Bridgeport and Hardinge Mills | 0 | 08-10-2010 02:38 PM |
| Need Help!- Communications Problem: PC--> Bridgeport Model R2E3 (BOSS 8) | rams_head | Bridgeport and Hardinge Mills | 0 | 03-04-2009 08:15 PM |
| R2E3 X-Axis problem | Jadaan27 | Bridgeport and Hardinge Mills | 1 | 09-06-2007 07:18 PM |
| R2E3 Boss 8 Axis limit problem | hrhoward | Bridgeport and Hardinge Mills | 4 | 05-30-2007 08:24 PM |
