Old 05-15-2011, 05:53 PM
arhctysv is on a distinguished road
EZ track drive error
Started by getting Y axis error. Found the motor bad got another motor
and fixed Y axis, but then got a X axis DAC Underflow error. Found a
red light on the Advanced Motion X drive, so I put it in Y and got the
same error, moved it to Z thinking we could run the machine in 2 axis
This time a green light was on all three drives. It let us home the machine,
but as soon as we homed it the Z drive light went to red and stops right
there. Do we have a bad drive or is something else going on? X and Y are
running OK and we can run 2 axis.
Old 05-15-2011, 10:11 PM
Moderator
machintek is on a distinguished road
The fault is following the drive to where ever it is placed. Sounds like a bad drive to me.
Did the Z home for you? Maybe you could reload the machine with 2 axis software.
George
Old 05-15-2011, 10:44 PM
Z will home out then the red light faults out on the Advanced Motion drive.
X and Y come up with the red light and won't home. Why will it let Z home out
then fault?
Old 05-15-2011, 11:16 PM
Moderator
Is it possible that the Z appears to be homing? It comes up but stops not because of the switch but because it is faulting. Are you getting a DAC overflow? Drives OFF? After the Z homes? Try moving the z down and starting the home process and press the switch and hold it with a screw driver or pencil (not your finger). I want to know if it stops and thinks it is home and allows the other 2 axis to home. If you know how to attach a full size keyboard, go to DOS, and to PFM,exe. You can home it there, watch the following error, and read the alarm codes.
George
VF2 SS Drive Error Delw Haas Mills 5 06-29-2010 11:11 AM
Need Help!- TM-1 Spindle Drive Fault Error ? AMCTony Haas Mills 6 01-26-2010 09:17 AM
Problem- TM-1 Error 162 Y Axis Drive Fault KevinWilkins Haas Mills 14 09-25-2009 08:57 AM
Arrow 500 Drive Fault Error macmub Cincinnati CNC 6 06-02-2009 12:46 AM
boss 8 drive error 4000 IeatSteel Bridgeport and Hardinge Mills 9 02-07-2007 02:20 AM
