Old 04-12-2011, 12:09 PM
dave the dragon is on a distinguished road
bridgeport xr760
does anyone know if you can do letter writing using the machine control on a xr760 heidenhain so far i,ve been using cad cam to write then transfer to machine, and this machine is brand new helppppppppppppppphttp://www.cnczone.com/forums/images/smilies/frown.gif
Old 04-20-2011, 01:05 AM
stripper is on a distinguished road
lettering
there is to my knowledge no lettering in the 760, i always use a program where i put all the letters ans numbers in a label and in the begin of the program i just put in coordinate shift cycle7 and a rotation cycle 10 and also a scale cycle11 this program copy into your program fill int the datum shift rotation and scale then call the apropriate lbl for your text and run dont forget if you write a program like this after every symbol put a datum shift in your lbl otherwise you write your letter on top of eachoter. sorry for the bad english but im from belgium hop i was a help for you.
Old 04-20-2011, 12:40 PM
i,m very interested in this form of programming lettering on the xr760 with labels for each letter stripper could you give me an example
Old 04-21-2011, 11:05 AM
i wil put the program as soon as ican on the forum if that is posible(if it is posible please advise me how to do it) otherwise i wil be happy to mail it to you with a explanation how to use it.
Old 04-23-2011, 02:18 AM
as promised the program for lettering in if you need help feel free tocontact me again every number or symbol has a lbl in rule 16 you can put lbl calls for your text try them all to see what lbl is what number if you need longer text just put in more lbl calls
Hardinge/BPt XR760 ATC ARM ParkerMillguy Bridgeport and Hardinge Mills 8 05-16-2012 12:18 PM
Need Help!- bridgeport xr 760 imac Bridgeport and Hardinge Mills 4 04-22-2010 03:40 PM
VFD for Bridgeport? M Spangler Phase Converters and VFD 0 12-27-2008 07:27 PM
Bridgeport DRO Pin Out bill south Bridgeport and Hardinge Mills 3 09-28-2008 03:52 PM
Bridgeport TC 1G Jeff Mckay Bridgeport and Hardinge Mills 1 12-18-2006 05:37 PM
