Old 04-09-2011, 09:35 PM
bgator220 is on a distinguished road
Setting up Bridgeport Explorer Encoder
Hello again,
Once I get the wiring for the machine right, I need to time the heidehein encoder that was just replaced. I was told that this could be difficult and could screw things up easily. The method I was told was to disconnect the belt to the z, and turn on the machine and let it home, then connect the belt. My question is how will the machine know its home if the z axis does not hit the limit switch?
Any input is very much appreciated.
Regards,
Brian
Newbie- Bridgeport Explorer X-26 & DX-32 Control SoCalRon Bridgeport and Hardinge Mills 4 01-31-2011 04:25 PM
Bridgeport Cnc Explorer 1 network TNBG_LTD Bridgeport and Hardinge Mills 2 10-21-2010 09:38 AM
Bridgeport Explorer X-26 \ DX-32 Won't Home XxLT250RxX Bridgeport and Hardinge Mills 2 04-23-2010 07:16 AM
Bridgeport Explorer CNCs arsenix Bridgeport and Hardinge Mills 9 02-10-2005 06:28 PM
