Hi, To make a long story short, I due to make a servicing on the z axis servo of my torq-cut 22. As I saw the bad shape of that axis, I decide to swap it with the X axis servo, which I also make a servicing on it due to a bad bearing. Now all servo in place, wired properly, I started the machine. After the boot, I've engage drives... all seems ok until I tryed to jog the X axis without homing the machine. It does a small move and then, an alarm came on which I don't remember (Im at home) Something like "Drive unable to command BMDC". I've search around the maintenance page and found a command to run a test. In this test all would go well except analog test. As I saw, both Z and X axis doesn't seems to have their good encoder adresses for the ???DAC??? Here is the question : Do I have to set the good adresse for each encoders somewhere in the software? It's just like the DX32 system detect that servo have being swaped. Anyone have a clue about this? I'll post more accurate info tomorrow. Thanks! Last edited by Wiseco; 04-08-2011 at 05:26 PM. Reason: Solved! |
| I tryed to delete this topic but... ![]() So the problem is solved. I didn't know how but after removing the servo from the machine, open it, made a carefull inspection without finding anything, put back things together and on the the machine : things works! Now I'll find a way to put a counterweight on the Z axis to that machine. If anyone have ever done it, I would like some photos. Thanks! |
| Need Help!- torq cut 22 problem | hawk1 | Bridgeport and Hardinge Mills | 3 | 01-08-2011 08:15 AM |
| Need Help!- Torq Cut 22 Tool Changer Problem | MetalicGlow | Bridgeport and Hardinge Mills | 8 | 12-08-2009 07:41 PM |
| TNC-145 - 150 control swap? | jkruger | Bridgeport and Hardinge Mills | 0 | 02-23-2009 03:17 PM |
| Motor swap | QSIMDO | Industrial Hobbies (Support forum) | 7 | 01-07-2008 08:33 PM |
| Spindle motor swap, or servo swap? | Chuck Reamer | Tormach PCNC | 28 | 10-09-2007 12:54 AM |
