Hey guys have a pretty good shape and lightly used bpt ezplus cnc mill. have been getting random z dac overflow errors when trying to run programs for students to learn setup/ dry running code. I popped the face open and found a faulty limit switch. swapped it out and still get a overflow error. the z axis motor got so hot that i couldnt touch the casing. it smelled like god knows what in the shop. weird this is, once cooled down i can easily turn the motor by hand. the z axis is not jammed up at all - also move it easily by hand. i have no idea if the servo motor is shot, the encoders are bad... any help is much appreciated. |
| It should not be counterbalance problem on a Z quill machine, so other than mechanical binding it would most likely point to too high a PID gain. Al.
| can ya run that by me again....where can i go to play with the pid #'s. I have never had an issue with this before (besides a z quill crash from a careless student in the past). is there a directory, way to access this info? love this place. Thanks |
| Tags |
| bridgeport, hardinge, servo motors |
| I keep frying bridge rectifier on power supply | js412000 | General Electronics Discussion | 4 | 03-27-2010 03:53 PM |
| Compare Catia and MCX2 for multi axis lathe/4 axis mill | bob1112 | General CAM Discussion | 0 | 10-10-2008 07:15 PM |
| New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter | the__extreme | CNC Wood Router Project Log | 3 | 02-26-2007 02:58 PM |
| When typing with a frying pan. | ESjaavik | CNCzone Club House | 2 | 10-15-2004 06:08 PM |
| How to Run a Large Stepper On A Small Board without frying | Sanghera | General Electronics Discussion | 8 | 04-27-2004 05:39 PM |
