First, I know this is a subject that has been beat to death, so I apologize for bringing it up again. I have a BP clone, new, and will be converting to CNC this year. I have most of everything figured out, but have a question about servos. I have seen DC and AC servos used. I have seen the AC servos used on bigger more expensive machines. Is that the way to go? Second question I would like to throw in is who provides a good quality ball screw set for a BP clone. I have gone threw several threads on this site, but most are pretty old.. and with the crappy economy it seems that a lot of these retailers have gone under. Thanks, Nik |
| not sure if they would work for ya but i have a set of 3 new panasonic servo motors and drivers. the drivers are 208-230 3 phase and the motors are 116v 3 phase with 2500ppr encoders. they are 750 watt. they accept torque mode velocity mode and step & direction mode. if ya inteterested i will accept a resonable offer they are brand new with cables. |
I am still trying to get an answer on the AC vs DC servo question. I can see that the AC motors are more expensive, and that a lot of the VMCs use them, I just can't see why. At this time I plan on driving the mill with EMC or Mach3. I can really customize a linux setup; which would be preferred. EDIT: I was just reading up on what I think is the Panasonic drivers you have. How familiar are you with them? This Full-Closed loop option has peaked my interest. My mill already has a good DRO on it and it seems to me in this mode the drive would be able to determine its position off the scale? This is intriguing, since my mill is new and the ACME lead screws in it are very good with little back lash. This will deteriorate over time, but would allow me to get the setup running before tearing it all down to install the ball screws. It would also remove any back lash issues, although minuscule, in the ball screws. Last edited by nikel; 03-14-2011 at 09:11 PM. Reason: Added content |
| yes the drivers supply it. driver panasonic model MSDA083A1A51 MOTOR PANASONIC MSMA082A1E they have 2.4nm of cont. torque. one thing on dc servos is the brushes. i have 2 ez-trak mills with dc servos. odd thing is the encoders on them is 250ppr. i thought it would have been higher. |
| AC servo motors have greater performance and better cooling. They are, however, more expensive and need to be matched to the drives correctly. They also do not have brushes to wear. i Last edited by ichudov; 03-15-2011 at 03:02 PM. |
| Just the small issues like lubrication, can really be a huge drag. i |
| I have considered this.. and still am, but my mill is damn new brand new. And I went through a lot of trouble to get it here and installed. I don't have access to heavy moving equipment. I don't plan on performing big production runs.. it is a hobby for now. If I were ever in the position to make it more I would got with a VMC. So, given that information, do you still offer the same opinion? |
| Yes, I have the same opinions. I also do not do production runs. When I bought my CNC Bridgeport, I sold my manual mill. I had to restore my CNC mill, as its control was obsolete and broken. Having seen a manual and a CNC Bridgeport mill, I formed an opinion that retrofitting a manual mill is a very troublesome approach. i |
#10
| nikel If you want to use servo's you should look at Dmm Technology They have AC servo's system that is a great price, & are very easy to set up http://www.dmm-tech.com/
__________________ Mactec54 |
#11
If I am over simplifying this please take a moment to correct me. I have seen about a thousand posts thus far across this the Internet debating this issue, and I am still stuck on why. |
#12
| nikel The Bridgeport CNC like the Boss series Is Very different to a manual, Some of the parts in the head are the same, but the rest of the machine is different There is nothing wrong with converting a manual machine to CNC, a set of Ballscrews that fit your machine, & you are on your way, Try Hiwin they have a good kit for most Bridgeports
| Tags |
| bridgeport, cnc, conversion, servo |
| Newbie- Bridgeport CNC conversion | chris123 | Bridgeport and Hardinge Mills | 14 | 01-23-2012 06:38 PM |
| Bridgeport Series 1 Conversion | GeorgeRace | Want To Buy...Need help! | 1 | 03-07-2011 07:30 PM |
| Bridgeport Clone CNC Conversion | Cartierusm | Benchtop Machines | 6 | 02-28-2009 02:03 PM |
| need help on my bridgeport conversion | pham1129 | Knee Vertical Mills | 3 | 07-07-2008 11:24 PM |
| Bridgeport cnc conversion? | Bryscnc | Bridgeport and Hardinge Mills | 10 | 03-10-2005 07:07 PM |
