Old 03-12-2011, 12:42 AM
fullbore is on a distinguished road
Bridgeport ez-trak dxII
Hello,
I'm trying to cut a half circle with cutter comp. When I program it, in the conversational mode, f2 cutter comp on I enter all the information. m arc, and I also enter all the required info then I turn c.c.off. What happens is the tool feeds over to the allowance position then I get an error of, no feed rate specified????I did enter it everywhere it asked.
Any and all suggestions will be very appreciated.
Old 03-12-2011, 09:38 AM
Moderator
machintek is on a distinguished road
That error is a software bug. Drove me crazy a few times too. It has been a long time but either you can try "comp one line" or you need to put in a few fake small moves because cutter comp looks 5 lines ahead. Thus if comp off is in those 5 lines it will never turn on.
George
Old 03-12-2011, 10:41 AM
Hi Gorge,
Thanks for the reply. Its not if the comp in on or not. It does turn on I can see it in the readout. Its the feed that it supposedly has none. Will the 5 lines ahead fix the feed problem? If it is a bug do I need to update software?
Need Help!- Ez Trak DXII Zombiestomp Bridgeport and Hardinge Mills 4 02-04-2010 06:15 PM
Bridgeport EZ-TRAK geno Bridgeport and Hardinge Mills 15 01-11-2007 03:31 PM
EZ-Trak DxII Cutting D's Instead Of O's Zombiestomp Bridgeport and Hardinge Mills 7 02-14-2006 12:21 PM
Bridgeport EZ-TRAK DX-2 zukes3140 Bridgeport and Hardinge Mills 1 06-20-2005 09:58 PM
Bridgeport EZ-Trak,to buy or not? BKP3855 General Metal Working Machines 1 11-01-2004 08:45 PM
