I'm having some trouble understanding what the heck this machine wants in it's g-code programs. When I try to run a program, sometimes it'll run thru, until I find an error, sometimes it won't run and other times it'll read right thru to the end M30 without doing anything. I've tried % signs at either end of the program, a colon at the start, the usual O1234 name format at the start, but I can't pinpoint what is the cause of my problems. My biggest problem is that I don't know if I should follow the DX32 programming manual I found, or should I try a Fanuc program? If anyone can shed some light, I'd appreciate it. Thanks |
Here is a program of a sprocket. I just posted the profile operation. This is the .pgm format. This works in the older EZTraks. I don't know if it will work in your EZVision or not. If your EZvision is like the EZtrak you should use the DX32 post. |
| Gncc50, I loaded the file that you sent me. When I run it the toolpath looks nothing like a sprocket. I'll try and attach an image of the on-screen simulation. Also, I run out of table travel in the Y axis, so I'm unable to run the entire program. ps, does your log-in have anything to do with the Grand National Cross Country series? Just wondering... |
| Newbie- EZVISION | lamebridge | Bridgeport and Hardinge Mills | 1 | 12-07-2010 11:05 PM |
| Bridgeport EZVision G-code help - Edgecam | lamebridge | Bridgeport and Hardinge Mills | 0 | 11-08-2010 10:57 AM |
| Need Help!- post for Bridgeport EZVision. | mgill09 | GibbsCAM | 1 | 01-26-2010 07:01 AM |
| Need Gibbscam post for EZVision. | mgill09 | Bridgeport and Hardinge Mills | 0 | 01-13-2010 11:33 AM |
| Mastercam 9 post needed for EZVISION MILL | SHREDNU | Post Processor Files | 1 | 06-09-2007 01:34 AM |
