Old 03-09-2011, 11:04 AM
Dyad1 is on a distinguished road
R2E3 Electronics
Hi all you R2E3 guys,
I have a problem one of you guys may be able to help with. We hadn't used our Boss8 machine for quite a while and when my guy went to set up a job the pulse generator for the .002" per step dial's shaft had gotten gummed up and would not turn. Well he forced it and instead of the shaft turning the whole thing loosened up and he twisted the wires off their lugs. A little WD40 loosened the shaft and the thing is fine but now I need to solder the wires back. I need to know which wire goes to which terminal lug. The wires are numbered 175, 176 and 177 and the lugs are numbered 1, 2 and 3. If anyone can help I would certainly appreciate it.
Gary
Need Help!- R2E3 sabian Bridgeport and Hardinge Mills 1 12-06-2010 11:04 PM
Need Help!- Need help with R2E3 problem. Revshift Bridgeport and Hardinge Mills 27 12-02-2010 11:14 AM
Communications with R2E3 rkdygert Bridgeport and Hardinge Mills 15 03-28-2010 11:26 AM
R2E3 Tooling dfmiller Bridgeport and Hardinge Mills 16 05-29-2005 04:51 PM
R2E3 memory DLMACHINE Bridgeport and Hardinge Mills 1 05-22-2005 03:23 PM
