Old 03-03-2011, 02:26 PM
arsenalandy is on a distinguished road
gross positioning error tnc 2500 mill
hi all recently i have been having problems ref z axis but put it down to bad weather placed a heater near the machine and its been ok
today it came up with z axis drive error , switched off back on and it cleared, then later on half way through the day just finished a cycle when it came up with "gross positioning error z " i had the electrical covers off and noticed on the third card along the was a red light on trf3 , switched power off again and it rereffed ok but soon came back with the gross error fault again any help would really be appreicated
thanks andy
Old 03-03-2011, 04:47 PM
cncserveng is on a distinguished road
Check the lubrication of the ballscrew and ways, seems to me to be a tight axis.
Check the axis % load on the axis servo page.
You may need to support the axis on a block and undo to ballscrew nut to get a feel for how tight is is.
Old 03-04-2011, 08:20 AM
Moderator
machintek is on a distinguished road
You can change the display to LAG. This shows the deviation between the commanded position and actual position. If it exceeds a parameter, it displays this error. These motors have brushes. May be that they are worn out and cannot transfer enough juice to the armature. Or you may have a tight axis as said.
George
Need Help!- Bridgeport Gross positioning error Ogre4x4 Bridgeport and Hardinge Mills 8 02-26-2011 04:45 PM
Gross Positioning Error Shanghyd Bridgeport and Hardinge Mills 3 01-21-2010 07:33 AM
Gross Position Error Mike Conboy Bridgeport and Hardinge Mills 18 06-15-2009 03:38 AM
Bridgeport Interact 4-Gross Positioning Error foolmaker Bridgeport and Hardinge Mills 7 01-15-2009 03:13 PM
HELP! Gross positioning error crazeekev Bridgeport and Hardinge Mills 6 09-09-2008 10:11 AM
