Old 02-25-2011, 09:14 PM
rlwoodjr is on a distinguished road
Series 1 CNC Rigid Ram
Hello,
I have been a member here for awhile in the DIY router forums. I finally decided to try my hand at machining with a Bridgeport. So far it seems to be in good condition. I have converted it to Gecko stepper drivers and I am using Turbocnc. I am using a static phase converter for the spindle motor. The stepper motors are from Centriod. It came with some tooling.
I am looking for a part list and a maintenance/repair manual and some history or date of this machine. It is serial number CNC 1696.
ID:	127454   Click image for larger version
ID:	127455   Click image for larger version
Name:	mill controller.jpg‎
Old 02-25-2011, 09:17 PM
Added computer stand
ID:	127458   Click image for larger version
Old 02-26-2011, 01:10 AM
TarHeelTom is on a distinguished road
Wow! You've done a nice job. One difference is that I'm putting all the electronics, including the computer, inside the power cabinet, where you've got a nice little cabinet there on the side. Was that already on the mill, or did you add it?
I have one quite similar to yours, but haven't quite finished the conversion yet. Was too hot to work in the garage in the summer, and too cold in the winter, so took a long break to insulate the garage. You can see mine at Tom Wade -- Machinist Section -- New CNC Mill.
Maybe you can help. I'm wanting to do various sorts of engraving, including lithophanes. Thinking of making a router mount which would mount in the spindle. I've got, for instance a monster 1" end mill holder. Was thinking of welding a 1" shaft to a holder for a router. Would like to keep the entire assembly as short as possible, and try to keep the router centerline matched up with the mill spindle centerline.
Any ideas what might be the most suitable router? Seen any router holders which would be more appropriate than others?
Tom
Old 02-26-2011, 08:26 AM
Tom,
I had the big box on the back full of transformers, but I wanted to put it close to a wall. A guy at work had the smaller box that I put the electronics in. I only kept the 2 spindle relays from the big box.
I have seen your web page before when I was looking for a mill. Great page for someone just getting started. Once I bought mine I started wondering how I would get it in the shop. I finally decided to remove a 4' section of wall. The guy I bought it from delivered it right to the shop floor.
I am not sure I would use the bridgeport for a router....maybe to make parts for a cnc router. Here is a link to the one I made for my dad:
http://www.cnczone.com/forums/diy-cn...d_one_dad.html
My Brridgeport has 18" in X, 12" in Y, and 5" in Z. A Larger DIY router project for engraving and lithophanes could be done for a reasonable amount.
I have plans for a 5 axis machine...but too many projects not enough time.
I used the small Bosch trim routers for mine.
ID:	127480   Click image for larger version
Old 02-26-2011, 09:11 AM
Originally Posted by rlwoodjr View Post
Tom,
I also need to put it close to a wall, so moved the power box to the side. Since I am using a VFD, I tossed the spindle relay. Actually, I don't foresee a huge demand for the low gear, so don't plan on using the reverse gear very often.
Good job on the table you're building for your dad. May get back with you if I decide to build a table. I don't particularly like the idea of using the Bridgeport for the lithophanes, but a couple of guys have shown some commercial interest in the lithophanes, so will use the Bp to make a few. If the interest turns to income, I'll then build a router mount for the BP, then start on a router table. Btw, what was your build time on your dad's router?
Big problem here is space. Seems like I saw a thread where someone built a router table which stands the work on edge.
Like your rotary drive. I stumbled across a 12" manual rotary table at a good price. Need to find a stepper for it, then turn a mount to hold it and drive the shaft behind the handwheel and I'll be in business. Also need to build a tailstock for it. But your rotary drive is probably all the size I really need, for the work I'd like to do.
But at least I had the foresight to buy mine in warmer weather ! ;>}
Old 02-26-2011, 05:42 PM
I can't really say how long it took to build the router because I only worked on it on select weekends. If I had to guess, I probably have 40 to 50 hours into it.
Space seems alway to be a little less than you need. Adding the bridgeport to the shop makes it a little bit more cozy...
I am looking for a rotary table for th BP...hopefully I will find one for a good price. Notice I made room for the 4th axis in the black box.
Did your BP come with any manuals?
Old 02-26-2011, 06:27 PM
Yes, my Bp came with a "full" set of manuals. Unfortunately the biggest manual, the maintenance manual, a 4" ring binder, is hiding from me for the last 6 months or so. I suspect that my former housekeeper helped me clean up by throwing it away...
I have added all the wiring in each location for a 4th axis, except that I haven't bought the Gecko yet. I have some definite projects in mind which require a fourth axis.
Have you considered cutting any lightning holes in the vertical plate in your gantry? Seems to me like that's the only part being moved by the X & Y steppers, and lightness would be a virtue, especially if it can be done without affecting rigidity.
Old 02-26-2011, 10:05 PM
The machine is now 8 hours away...
I am sure it could be done, I am not sure how much it would help. You could take material from the middle of the vertical piece (the neutral axis) and make it a little bit lighter without changing the rigidity much.
Old 02-26-2011, 10:11 PM
I was wondering if there was a maintenance manual.
I have found the operators manual for the M128-B on Ebay, I have that one.
Anyone know of a place to get the maintenance manual for a M128-B?
Old 02-27-2011, 09:57 PM
HawkJET's Avatar
HawkJET is on a distinguished road
Have you looked at Machine Manual Services
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." Antoine de Saint-Exupery (1900 - 1944)
  #11   Ban this user!
Old 02-28-2011, 09:23 AM
I have seen this site before, but I did not find a Series 1 CNC M128B maintenence manual. I do not know what Boss mine is? I thought the Boss was a name for the electronic/cnc part of the machine. How do I determine which boss I have or which manual to buy?
  #12   Ban this user!
Old 02-28-2011, 09:56 AM
HawkJET's Avatar
BOSS is an acronym for Bridgeport Operating System Software. The Series I iron is the same on all the BOSS machines. Since you don't use the electronics or software anymore, it would seem to me that it won't matter which one you got. The more recent models have more bells and whistles that may not be applicable to your hardware.
Also, the afore mentioned site has a section on serial numbers and build dates if that is important. I have a BOSS 3 with serial number 499. TarHeelTom has a BOSS 5, and it may help to know his number. The manual you said you have seems to be for a BOSS 3. The photos of the machine being delivered have no distinguishing features.
In the photos, it appears that you have encoders on the back of the motors, is this the case? Who put them on?
EDIT: I just noticed the serial number section of the above web site doesn't appear to include the BOSS machines. My guess from your serial number is that you have a BOSS 5 like Tom's.
Multicam 3000 Series vs AXYZ 5000 Series adamfilip Commercial CNC Wood Routers 1 10-18-2010 02:54 AM
oiling series 1 rigid ram DrStein99 Bridgeport and Hardinge Mills 3 11-08-2009 08:04 PM
What exactly is Rigid tapping? Why people always ask does it do rigid tapping? cjchands General Metalwork Discussion 23 12-19-2008 08:19 AM
Update on tramming the rigid ram Series 1 swarf_rat Bridgeport and Hardinge Mills 2 06-16-2007 12:16 PM
What is the Difference between 6000 series aluminium and 7000 series Kosta1234 General Material Machining Solutions 3 11-19-2005 08:04 AM
