Old 02-20-2011, 09:52 PM
dirtdiggler is on a distinguished road
Rigid Ram Z ball screw issue and question
On my recently retrofitted Boss 9, at some point in it's life the quill crashed upward and bent the 1/4" metal plate bolted on the top of the quill that makes contact with limit switches. It's bent maybe 6 mills from impact.
I recently removed the metal contact place and re-bolted the quill to the ball screw to check for alignment problems. I notice that when I turn the ball nut with the pulley by hand that the quill starts to bind in the quill housing at certain points. For instance If the pulley is turned half way (180) the quill can rotate in the quill housing freely by hand, and when the pulley is turned all the way (360) the quill gets stiff again and cannot rotate freely. So my question is, is there anything I can do to re-adjust this, or is the ball nut, pulley or ball screw likely bent or warped?
I still get decent accuracy but I am noticing that the quill is getting uneven wear and scouring on the chrome.
Any advice would help. Thanks
Ball Screw Issue please no smoke General Metal Working Machines 8 12-05-2010 04:32 PM
Ball screw question. Nth General Metal Working Machines 6 08-25-2010 01:48 PM
Ball screw question from a new guy! ben_kapitan CNCzone Club House 2 04-18-2009 10:19 PM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 12:10 AM
Ball Screw Question jjwl89 DIY-CNC Router Table Machines 13 07-20-2004 07:12 AM
