Old 02-16-2011, 07:03 PM
Ogre4x4 is on a distinguished road
Bridgeport Gross positioning error
Gday
I got a Interact 308.
When i start the machine and start the Z reference the X is slowly moving also. Then i get the Gross positioning error.
Is the Clamps for the X stuffed???
What can i do???
Luke
Old 02-16-2011, 09:41 PM
Moderator
machintek is on a distinguished road
If a axis drifts it means that the positioning system is compromised. Typically encoder or cable. Swap x and Y motors and see if the problem follows the motor.
Also there were different versions of controls on the 308. The later ones had siemens drives.
George
Old 02-24-2011, 09:13 PM
Hey
Thanks. I have begun to swap motors.
Before i start pulling them out i found i was able to turn the X motor by hand but the y wont move.
Is the motor the only thing that keeps it still when not in use or are there clamps when stationary?
Does this narrow it down at all.
Im guessing that by swaping motors i can see if the wires are stuffed or the motor?
Luke
Old 02-25-2011, 07:13 AM
Moderator
Z has a brake. Y does not and should move (and home 2nd). X should not drift but home when the Y is finished. Sounds as if you have multiple issues.
George
Moderator
George
Old 02-25-2011, 07:42 PM
Well i swapped motors anyway... it seems to have fixed something... dont know why.
I can no longer move x by hand...
We will see how long it lasts with the motors swapped.
Old 02-26-2011, 01:29 PM
awemawson is on a distinguished road
Motors swopped
Which would imply that you had a bad connection somewhere that you have moved as the motors were exchanged. I'd do a 'wriggle & tap' test 'in the manner of a reasonable man' on your various leads, plugs etc
Andrew Mawson
East Sussex, UK
Old 02-26-2011, 02:55 PM
gus gus is offline
gus is on a distinguished road
Old 02-26-2011, 04:45 PM
Reasonable Men
This phrase was written into the backplane testing specification for Ferranti Argus 500 process control computers back in the 70's, where we were called upon to tap on the multi-layer plus wire wrapped backplane with a screwdriver handle 'in the manner of a reasonable man'. It did on occassions show up intermittant faults. Ferranti in those days was a company run by gentlemen, and such style of phrasing was not uncommon! I was with them for the best part of thirty years in one role or another.
Andrew Mawson
East Sussex, UK
Gross Positioning Error Shanghyd Bridgeport and Hardinge Mills 3 01-21-2010 07:33 AM
"Gross Postioning Error A" Doing M03 on Bridgeport Interact Series 1 Mk2 MeTri Bridgeport and Hardinge Mills 5 12-27-2009 11:37 PM
Bridgeport Interact 4-Gross Positioning Error foolmaker Bridgeport and Hardinge Mills 7 01-15-2009 03:13 PM
HELP! Gross positioning error crazeekev Bridgeport and Hardinge Mills 6 09-09-2008 10:11 AM
Bridgeport VMC308 - Gross Position Error mcwmah CNCzone Club House 7 11-09-2007 03:34 PM
