Old 02-14-2011, 02:24 AM
Sroe1 is on a distinguished road
BP Series I R2C3 w/ 151b controler
used to have a 145 control now installed a 151 control.
Symtoms are the machine boots up normally, no errors reported and the enables button clicks on and stays on, but servos don't run and will not traverse the axis for the initialization.
the servo drive cards have a "ignition release" LED's that should be but are not lighted, so i know that is why the drives are not activated.
but i don't know why the controler won't enable the servo drives.
I have checked the 24 V and it is present at the controler. the logic system uses this also but can not find the fault yet. The lube is not low, i jumpered those wire as the float was bad. The servos and such used to work fine and have not had much use, but now it will not run with the new control.
Anyone have any clues as to what to check? i have the wiring diagram and trouble shooting guides so something to go on, but i have very limited experience with the hiedenhain controler and the typical failures with the series I R2C3mills. Any one with advise or similar experience they can share?
Old 02-14-2011, 07:22 AM
gus gus is offline
gus is on a distinguished road
I have this exact combination, so I know it works
Is the control known good?
If the enable stay enabled the drives should be enabled, there is a light IIRC that comes one once they close the loop, but a couple that come on when they power up
will the spindle fire?
what parameter set did you use?
Old 02-14-2011, 02:15 PM
your right the 2 types of lights; the ones that show the drives are powered up are on. the lights that show ignition, i guess closed loop are not on.
i thought it had to close the loop to traverse the axis.
but maybe not.
Spindle won't fire either. nothing.
parameters i used are from here;
http://igor.chudov.com/manuals/Bridg...Parameters.pdf
used to run fine, controler boots and is stable, but not known good, but was told it was good, and it behaves (boots) like it is fine but nothing will move??
Old 02-14-2011, 03:51 PM
gus gus is offline
If your spindle won't fire then you are not actually enabled.
I just checked on mine, it does not need to be homed to fire the spindle, just enabled
there is a thread here with a title like heidenhain parameters with IIRC my exact parameters in a downloadable list[how useless is a pdf or image]
check fuses and such
Old 02-14-2011, 04:08 PM
gus gus is offline
I cannot find my parameter list on this computer, it must be on my half dead laptop
Old 02-15-2011, 01:02 AM
Thanks Gus, i will look into that.
so far no clue all fuses are good
something is not happy though, i think i need to check the drives/cables
and make sure they are talking. and the relays are all working, i believe it
must be one of the interlocks on the logic which is all 24V stuff
i looked for you parameters, can you re-post here? i did not find them.
Old 02-15-2011, 01:05 PM
gus gus is offline
posted in parameter thread
check vs yours rather than use wholesale, machine is not fired up and connected today so I cannot be sure this is current 'rev'
Old 02-15-2011, 01:35 PM
Thanks Gus,
where did you post them, sorry i dont' see anything here?
Old 02-15-2011, 03:44 PM
gus gus is offline
looooooook
http://www.cnczone.com/forums/bridge...ter_lists.html
Bridgeport Series 1 R2C3 Problems Vigilance Bridgeport and Hardinge Mills 3 12-28-2010 05:21 PM
Heidenhain 151B featurecam post processor maybe4x Bridgeport and Hardinge Mills 0 06-20-2008 06:06 PM
Heidenhain Tnc 150b, 151a, Or 151b Control Gute General Metalwork Discussion 2 09-17-2007 08:07 AM
Strange circle behavior, 151B control swarf_rat Bridgeport and Hardinge Mills 11 07-15-2007 09:08 PM
BP Series 1 - what can I rip out after a BOB Controler/Mach3 upgrade? bbuonomo Bridgeport and Hardinge Mills 2 10-27-2006 02:26 PM
