Old 02-12-2011, 11:16 AM
theo1 is on a distinguished road
Bridgeport Interact 2 Series 2 TNC2500
Hello all,
I'm pretty new to the forum and bit of a newbie with CNC maintenance.
Hopefully someone can help me. Ive already looked through the history of threads, and people are having similar problems but not identical, so thought Id ask.
We have a Interact 2 Series 2 with TNC2500.
Just had the machine installed and wired up.
When power on the machine does the normal memory check, then 'Power Interupted'. So then I press CE and the machine progresses to the screen for passing over the reference marks. All good so far.
When 'ENABLE' button is presses, the machine errors out.
The error code is 'GROSS POSITIONING ERROR X D'.
From looking online, it seems there could be a few causes for this.
Any suggestions anyone.
Thanks in advance
Theo
Old 02-13-2011, 11:33 AM
awemawson is on a distinguished road
Heidenhain Errors
To quote from the Heidenhain web site
"Standstill Monitoring
- The deviation from the nominal position of an axis in
standstill has exceeded the value programmed in
machine parameter 1110.
- The nominal position was moved beyond during
positioning (overshooting)."
Andrew Mawson
East Sussex, UK
Old 01-18-2012, 06:47 AM
andyp72 is on a distinguished road
could be the limits of the machine are not correct check your parameters
Old 01-18-2012, 07:07 AM
Moderator
machintek is on a distinguished road
He has not pressed the GO button to initiate motion. Sounds like motion has started on the X axis without being asked. Probably a BOSCH drive issue.
Did the machine run before you bought it?
George
Old 01-19-2012, 05:14 AM
gridley51 is on a distinguished road
George,I think he`s calling the enable button GO.
Theo,Is it off the reference marks when it asks you to reference?
Is X the top line?
It should be Z on top.
Someone may have been messing with the parameters
Need Help!- bridgeport series 2 interact 4 dcchip Bridgeport and Hardinge Mills 3 11-15-2010 04:47 PM
Need Help!- bridgeport series 2 interact 4 dcchip Bridgeport and Hardinge Mills 5 04-30-2010 07:27 PM
Need Help!- Bridgeport Series 1 interact tnc 145 jaztau Bridgeport and Hardinge Mills 2 10-20-2008 04:12 AM
Need Help!- Bridgeport Series 1 Interact zorba99 Bridgeport and Hardinge Mills 7 06-11-2008 07:59 AM
Problem- Bridgeport Interact 308 w/TNC2500 GarageShop Bridgeport and Hardinge Mills 4 03-24-2008 05:43 AM
