Old 02-11-2011, 11:29 AM
dzcatic is on a distinguished road
Problem on Bridgeport VM 1000
I got an error "C300 Zn track Y error" on my Bridgeport VM 1000, does anyone know how to fix it?
It tells me to press END button to reboot, and after rebooting i got the same error.
Old 02-11-2011, 10:28 PM
rmarchjr is on a distinguished road
Sounds like an encoder or drive failure.
I'd track the cable and check for a break, then switch the X & Y motors, they should be the same, if problem persists in Y then likely bad drive, if error moves to x, encoder/motor.
Good Luck
Bridgeport VMC 1000 XP3 cncdon CNC Machining Centers 6 01-28-2011 11:47 AM
Bridgeport VMC 1000 417m Open Source CNC Machine Designs 1 01-07-2011 12:12 PM
bridgeport VMC 1000/20 spddsgn Bridgeport and Hardinge Mills 2 10-10-2010 08:52 PM
Bridgeport VMC 1000 kayleesdad Bridgeport and Hardinge Mills 10 01-09-2006 10:56 AM
Bridgeport VMC 1000 kayleesdad General Metal Working Machines 2 07-18-2005 10:20 AM
