Old 01-27-2011, 06:08 PM
anslee is on a distinguished road
hardinge vmc 600
i have a hardinge vmc 600 when you cange tools it removes tool from spindle indexes the carousel to new tool and times out over tool when you reset control it alarms out tool counter. you can rotate carousel around both directions without changing tools and it does not loose count. checked tool clamp and unclamp data bits and it shows to be clamping and unclamping it does not do it on every toolchange it does it on around every 4 or 5 changes just enough to make the changer useless. prox switches appear to be triggering by monitoring data bits. please help
thanks
Hardinge GT 27 outctrl Hardinge Lathes 0 10-12-2010 09:55 AM
Hardinge HNC Artitus Hardinge Lathes 0 06-12-2009 04:29 AM
Need Help!- hardinge hct help..... Jay Warren Want To Buy...Need help! 0 01-04-2009 10:49 AM
Need Help!- Hardinge HLV-H atscnc General Metal Working Machines 1 07-21-2008 03:05 AM
Hardinge - 59 DLMACHINE Vertical Mill, Lathe Project Log 1 04-02-2006 08:42 PM
