Old 01-24-2011, 11:06 AM
fastcarl is on a distinguished road
bridgeport series 2 speed controller playing up
Hi Gents, it was working just fine this morning and when i came back from lunch the damn thing is playing up,
when i press the button to either increase or decrease speeds i can hear the air valve on the side of the body opening and shutting ok, but the indicater disk just moves a tiny amount , at a time , after numerous presses it stops mpoving altogether,
but whilst the macjine is runnnig with thw air line attached there is air leeking out of what i assume to be a blow off valve,
if i disconnect the line for a few mins then re attach i can move the indicater a 150-200 hundred revs then it stops again. al the time air is leaking out of the side of the valve box thing ,
i sounds to me like not enough air pressure to move the gears as it is leaking as above, there is plenty preasure in the main air line
anyone any ideas,
i'm sure it something and nothing [or i hope it is]
help please,
regards carl
Old 01-27-2011, 02:12 PM
Moderator
machintek is on a distinguished road
Maybe a bad solenoid? They can be disassembled and examined. Sounds as if the spool inside is hung up or has a seal that gave out.
George
Old 01-27-2011, 02:41 PM
re
Thanks men, i suspect a seal, i'll pull it apart and hopefully find something obvious
carl
Bridgeport Series 2 interact 2 controller woes Teyber12 Bridgeport and Hardinge Mills 6 10-31-2010 05:19 AM
Bridgeport series I mill using dynomotion controller krz2_2000 Bridgeport and Hardinge Mills 21 04-06-2010 02:34 AM
Newbie- Advice on purchase of Bridgeport series I with BOSS controller leop Bridgeport and Hardinge Mills 13 03-31-2009 06:27 PM
Help with Bridgeport Series I with Textron controller? rhemp Bridgeport and Hardinge Mills 2 07-12-2007 10:55 PM
Bridgeport Series I Boss 5 Controller VIC H General Metal Working Machines 0 07-24-2006 11:54 AM
