Old 01-21-2011, 11:45 AM
jrlandau is on a distinguished road
What's that gizmo across the contactor coil?
Hi All,
On a Bridgeport Series 1, attempting to turn the spindle on blows a fuse in the 120v circuit (Fu4, 6A). So I'm thinking I have a problem in the contactor or the switch, especially because the previous owner had problems with the contactor (he priced a replacement, but didn't replace it). Advice is welcome.
In particular, what is the device that is wired across the coil of each of those contactors, and how do you test it? The schematic uses a symbol I can't identify, looks like a capacitor connected to something represented by a rectangle!
Thanks,
Joe
Old 01-21-2011, 11:53 AM
Al_The_Man's Avatar
The two likely hoods are Varistor or (R/C) resistor/capacitor snubber, my guess would be a R/C type, this is to suppress any back EMF spike.
If R/C type a test with a meter should show open.
The varistor should not be discoloured and show high resistance.
Post #2, http://www.cnczone.com/forums/genera...ion_error.html
Rewinding a coil Shanghyd General Electronics Discussion 1 10-22-2010 06:49 AM
Need Help with Magnetic reversible Contactor Chris64 General Electronics Discussion 12 12-23-2007 02:54 PM
Coil Winder itsme I.C. Engines 6 08-25-2006 01:12 PM
testing a coil Fabric8r General Electronics Discussion 1 06-09-2006 08:30 AM
Contactor help ???? Fabric8r General Electronics Discussion 1 05-26-2006 05:27 PM
