I have an older Bridgeport Series I mill with a 1.5HP US Motors motor on it. The wires were cut at the electrical box on the motor. How do I know which wires are which? I see there are two sets of wires bound together. One set has 4 wires while the other set has 5. Any help would be appreciated as I would love to get my mill going. |
| Do I see little bands wrapped around each wire about a quarter inch wide? Those may be the missing wire numbers. Take a look. George
| There should be three wires from the motor connected together, and then each of the 3 phases from your converter should hook up to 2 wires from the motor. Line 1 connects to T1 and T7 Line 2 connects fto T2 and T8 Line 3 connects to T3 and T9 connect T4, T5 and T6 togeter and tape off. Thats about all I remember...please be safe if you give it a try. |
| They sure look like the ID bands to me, have you tried really cleaning them off? This is a list of most motor connection details if you try and reverse engineer it. Connections Nine connections is usually the typical double star connections for either 240/460v operation (parallel or series star). Al.
#10
| Using the img below verify the setup see image below look at the WYE configuration this is most likely what you have. You can verify this with a ohm meter Last edited by Perfect Circle; 01-12-2011 at 08:00 AM. |
#11
| The ID numbers were on the clips. There clips were so dirty that they had to be cleaner quite a bit before the numbers were visible. I can see the wiring on the label, even though it too is barely visible from the fire the mill was in. Thanks! |
| Bridgeport Series I X/Y CNC motor mounts | ChrisBruno | EBAY ADS | 0 | 10-27-2010 12:43 PM |
| Bridgeport series 1 and teco N3 wiring | cruzin | Bridgeport and Hardinge Mills | 11 | 10-01-2010 10:14 PM |
| Need Help!- Wiring Bridgeport motor question? | CATCH22 | General Electronics Discussion | 1 | 05-13-2010 10:22 PM |
| Series 2 cnc 2 hp motor on a series 1 bridgeport? | CATCH22 | Bridgeport and Hardinge Mills | 1 | 11-08-2008 08:18 AM |
| Identifying Bridgeport Series 2 Interact 4 Spindle Motor | UKRobotics | Bridgeport and Hardinge Mills | 2 | 05-26-2006 06:55 AM |
