Hi All, Have an Interact II Series II machine and has been running well. We lost power a number of times in December and now I get an error code about 5 or ten minutes after I power up the machine and home the axis. I can only see about half of the top line of the old screen and it says something like: IMC ELECTRONICS FAULT. It could be YMC or TMC, don't know. I can run the machine prior to the fault. Any ideas? Thanks, H |
Went through cabinet again last night checking for any loose connections etc. Powered up machine, homed, loaded a program (748 lines) and got to line 435 when the electronic fault occured. Powered down to reset and did not even get through the homing process before it faulted again. Does TNC 151 have the 1000 line limit? How comparable is it to a Mach3 or EMC upgrade, operation wise? We've got a Clausing with Delta 20 also that has started giving RAM faults so it would be nice to have a "standard" operating interface. Any thoughts? Thanks, H |
Just for kicks I pulled the Y motor because it had started being louder than normal and when I did the X motor it really smoothed things out by cleaning it up. Pulled the Y and cleaned it up, put it back together and started things up. No Electronics Fault. Set my datums, checked tool lengths, loaded and ran a program. No faults. Left power on main power on overnight with the e-stop on. Started up this morning and ran the program no problem. Hit the e-stop and was going to run another program this afternoon. Looked at mach a bit ago and it had the blinking Electronics Fault. Powered down and restarted but it faulted out again. Not having a list of error codes I can only guess that this is a control issue. Motors / encoders seem to work; power supply seems to work, that would leave the drive boards and the main control. I can't really read the error message; IMC or YMC maybe, Y motor control? If I found a 151 control would that use my existing power supply and driver boards? Any thoughts? Thanks, H |
Thanks Gus, Yes, the screen just blinks TNC Electronics Fault at the top. So like you said in your earlier post the 151 control would bolt right up to my existing power supply etc? Or, get the complete control w/power supply, drivers etc and replace everything? |
#10
it should just bolt right in, 4 bolts slide it on out, the encoder cables screw in, monitor plugs in, and there are 4 strip connectors with all the little wires that will unplug from the pc board on the back and plug them onto the 151, it is pin for pin compatible. |
#12
| I was having trouble with a TNC 151 on an Interact I mark II. I talked to Rick at Heidenhain in Chicago and he said sometines just pulling the boards from their slots and then replacing will fix the problem. Bad contacts. Make sure you have all the parameters written down because you will lose them when you pull the boards. I was getting a check sum error. Don't know if it will work, but just had to add that information. Thanks , Dan |
| VMC15 fadal, 88HS error#9, spindle driver fault, servo amplifier fault | kin73 | Spanish CNCzone | 3 | 05-17-2011 11:26 PM |
| Inverter fault / Drive line fault ? | TMILLS | Fadal | 2 | 10-20-2010 09:20 PM |
| Problem- Bridgeport Interact 720 VMC Axis fault error | FLjoyride | Bridgeport and Hardinge Mills | 51 | 01-06-2010 06:55 PM |
| Need Help!- Bridgeport Interact 4 spindle drive fault! | foolmaker | Bridgeport and Hardinge Mills | 5 | 01-14-2009 06:51 AM |
| Interact 1 mk2 z measurement fault | iknownothing | Bridgeport and Hardinge Mills | 4 | 08-06-2008 12:37 PM |
